How to remove engine from car (5S-FE) |
Dec 10, 2013 - 12:06 AM |
Ok this is how I did it, some steps can be done in different orders. This is for information only and I am not responsible for any oops on your part.
Lets get started Here is your engine bay, First remove the hood. Unplug the water line for the squirters and remove the (2) 12mm bolts on each side of the hood. Jack the front of the car up and drain the oil. Remove the battery Remove the (3) 10mm bolts holding the cruise control actuator. remove the plastic cover Using 14mm wrenches, loosen the nuts securing the throttle cable Unplug the cruise actuator Now with the actuator in your hands, rotate the cable to remove it from the actuator Unplug the radiator fans Under the radiator, unscrew the plastic drain cock and let coolant pour out into a bucket Unplug the Radiator temp sensor Remove the radiator hoses remove the (2) radiator clamps, each held in with a 12mm bolt Unplug the other fan plug Lift out the radiator drain the transmission fluid, remove this bolt, its a 24mm While that's draining, remove the stock airbox, first remove the snap clamps and the spiral clamp around the intake hose. there are (3) 10mm bolts holding the airbox in. 2 are inside the box and the last one is outside by the fuel filter. Remove this grounding cable, there are (2) 10mm bolts here and a single 12mm bolt on the transmission right next to the reverse switch remove the fuse box cover Push in the tabs to lift up the junction box (what i call it) Unplug the harness from both sides. the white plug is a typical plug, push in the tab and lift. the large connector you have to push in the tab and rotate the lock down. Unplug the igniter and resistor box remove the diagnostic box This is the EVAP purge VSV, I believe this is only on 99 Celicas. unplug it if you have it, follow the hose up to the intake manifold and unplug that too. Loosen the other spiral clamp on the hose at the throttle body. its a 10mm head with a phillips screwdriver so either will work This is the return fuel line, remove that and remove the fuel feed line at the filter. Its the 17mm Banjo bolt on the filter right next to the EVAP VSV This is the MAP sensor, unplug it This is the harness going through the firewall to the ECU. its held in by (2) 10mm nuts. This line feeds the brake booster you can remove it from either side or both and just get it out of the way This is a vapor filter for the MAP sensor. be careful removing the hose. you don't want to break off the nipple Remove the passenger side foot trim. this will make it easier to pull the harness through and easier to get to the AC plug This is the AC plug, don't forget to unplug it. I forgot to mention these, remove the small clip to free the shifter cables, then use large pliers to get out the C clips that hold the cables in place. Back to the ECU, unplug the ECU, Circuit Opening Relay, and the body harness. Carefully lift out the harness Ok lets get the alternator out of the way. First loosen the pivot bolt. Remove the sideways bolt, that clamps the alternator in place, then take out the long tightening bolt. remove the electrical connections Alternator removed, Now lets get the AC compressor out of the way. First unplug it There are (3) long 12mm bolts holding the compressor to the block. remove those and let the compressor down out of the way. Not too much is left, by now the transmission should be drained, if you haven't done so already, put the drain plug back in. Now take off the wheels. Remove the cotter pin and nut cover. Stick a screwdriver in the rotor and brake caliper. this will hold it in place while removing the 30mm axle nut Remove the ABS sensor if you have one, unclip the harness and get it out of the way Remove the brake caliper. there are (2) 14mm bolts on the backside. once those are out remove the brake pads. Smack the axle with a dead blow hammer. this will knock it out of the hub Remove the (2) 19mm bolts from the hub to strut. pull the hub away and the axle will be free With a friend holding the axle straight and rotating it, use a pry bar on the CV housing at the transmission and pop out the axle. It will come, you just need to find the sweet spot. The passenger side is easier, remove the (2) 14mm bolts from the axle bearing carrier and the axle will slide right out Spray some penetrating oil on the exhaust bolts. let that sit for a while and then remove the 3 bunts holding the downpipe to the header. Remove the locking bolt on the power steering pump. I should have circled it, loosen the pivot bolt on top of the power steering bolt, if you can get it out here, that's awesome, I had to jack the engine up to get clearance. Here is another pic of the fuel return line unplugged and the feed line. if you haven't done so, remove them now. Remove the 2 water lines for the heater. Its hard to see here, but looking in through the drivers side wheel area, this is the rear engine mount bolt. its in the shadows. If its hard to get out, come back to it after removing the front mount. rock the engine and you should be able to pull it out. Remove the Front engine mount, its a 17mm bolt through the mount. then remove the (2) 14mm bolts on the bottom. lift out the mount. then remove the bracket from the transmission. Now get your hoist ready and hook up. Remove the starter, first the 12mm nut for the hot feed, then the ground plug. there are (2) 14mm bolts on each side holding it on the transmission. Unplug the reverse switch to get it out of the way. Now free the slave cylinder. remove the 10mm bolt securing the hard line, the (2) 12mm bolts on the slave and the 10mm bolt in front of the transmission Remove the drivers side engine mount. its a 14mm long bolt and (2) 14mm nuts and a short bolt. then remove the bracket from the transmission. Those are 14mm also Remove the passenger side engine mount. Start to lift the engine, here you can see the power steering bolt that gave me trouble. now you can pull it out and set the power steering pump aside And out it comes And finally the MONEY SHOT This post has been edited by Smaay: Feb 27, 2014 - 6:07 PM -------------------- 2001 Celica GT-S Turbo
Dec 10, 2013 - 12:15 AM |
Here is a preview of whats to come
Dec 10, 2013 - 12:18 AM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
Great writeup! I'm surprised in all the years this forum has been around and the countless engine swaps done that this has never been made before.
Enthusiast Joined Oct 20, '13 From Cal Bay Area Currently Offline Reputation: 0 (0%) |
Killer documentation. Thanks for taking the time, Smaay!
I just did this for the first time myself. With these pics an instructions it would have been easier no doubt. |
Dec 10, 2013 - 12:32 AM |
Enthusiast Joined May 30, '12 From CA/NV Currently Offline Reputation: 0 (0%) |
Money shot...ummm yeah sure, that works too
Here is a preview of whats to come Thanks for working so hard on this! I'm excited I get to learn so much in this project! -------------------- 2004 Celica GT-2zz w/6-speed swap
1999 Celica GT-3sgte swap 1993 Celica All-Trac 1997 Celica ST/Limited-rip 1993 Celica GT-rip my first love |
Dec 10, 2013 - 12:39 AM |
yup, great documentation. Everything was covered. So we need to sticky this. good job. Interesting way to remove the axle bolt. I used to put the wheel back and lower it. but it takes longer.
Dec 10, 2013 - 1:17 AM |
Enthusiast Joined May 23, '12 From northridge,CA Currently Offline Reputation: 3 (100%) |
I am impressed thanks for covering the part I forgot to mention lol
Dec 10, 2013 - 10:08 PM |
Enthusiast Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Great write up.
That turbo manifold.... I am interdasted Who made it? -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Dec 10, 2013 - 11:19 PM |
Enthusiast Joined Jan 12, '09 From State College, PA Currently Offline Reputation: 1 (100%) |
Fantastic write up. It's EXTREMELY helpful when things are pointed out and done step by step as you did here.
As for money shot... mine was in the background. Supra has always and will always be my favorite car. Has been since I was 8 years old living in NYC and saw one drive by. Didn't know what it even was until I saw another after I had moved and 6 years had passed. I'm not allowed to blow most of my recent inheritance on a '98 RSP, wife would kill me and I wouldn't be able to deal with having to sell it down the line... which would happen. Baby Supra will have to do for now. This post has been edited by cardshark525: Dec 10, 2013 - 11:23 PM |
Dec 10, 2013 - 11:42 PM |
Enthusiast Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
-------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( Click here to see my progress thread! |
Dec 11, 2013 - 12:20 AM |
Dec 11, 2013 - 12:55 AM |
Oh damn! Niiice -------------------- 2007 Impreza 2.5i - Daily
Dec 11, 2013 - 1:08 AM |
I couldn't help but expect two more cylinders to be going back in. Very nice write-up with lots of information.
Dec 11, 2013 - 3:47 AM |
Next time I'll be sure I'm not "obstructing" the Supra view...or wearing a bikini smh! I couldn't help but expect two more cylinders to be going back in. Very nice write-up with lots of information. Don't worry, the v6 will go in next once I'm done playing with the turbo -------------------- 2004 Celica GT-2zz w/6-speed swap
Dec 11, 2013 - 5:34 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Baby Supra will have to do for now. You mean the Pappa Celica has to do for now. The Supra line is based off the Celica. -------------------- |
Dec 11, 2013 - 7:29 AM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
sweet write up!!!
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Dec 11, 2013 - 10:48 AM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Well done dude
Dec 18, 2013 - 12:52 AM |
Enthusiast Joined Dec 3, '13 From Missourah Currently Offline Reputation: 0 (0%) |
You had me at Money Shot.
-------------------- Bust a Deal; Face the Wheel.
Dec 22, 2013 - 5:39 PM |
Great write up. That turbo manifold.... I am interdasted Who made it? this is the manifold from the kits i made for the 5S. However nobody else bought one since it never got finished. the turbo system is sound, its the tuning that a problem -------------------- 2001 Celica GT-S Turbo
Dec 25, 2013 - 8:23 AM |
Oh so that's one of the prototype kits. Nice.
I like the manifold. How much do you sell it for? -------------------- 1993 Celica GT Coupe - sold
Lo-Fi Version | Time is now: March 28th, 2024 - 8:32 PM |
