Closed TopicStart new topic
> The Forced Induction Thread. (turbo, supercharger, nitrous), Check this thread for great information first.
post Feb 4, 2011 - 9:32 PM
Rusty
Joined Nov 5, '07
From New Zealand
The Forced Induction thread.
Turbo Introduction
Information about Turbo systems. Covering: Basic, Advanced & Expert. - Great info and answers for FAQís for beginners to experts.
How to read compressor maps. - How to read Compressor maps and pick the right Turbo for your project.
7A-FE+T & 7A-GE+T
7A-FTE, info on what not to do. - A great collection of 7A-FTE doníts, by the 7A-FTE guru, OOBE.
Turbocharging your 7A-FE. - A How to article, on how to turbo your 7A-FE.
5S-FE+T & 5S-GTE
Turboing your 5S-FE, the BIG 5S-FE+T post. - If youíre looking at turboing your 5S-FE, you want to read this.
From 5S-FE or 7A-FE to the 3S-GTE
5S-FE (and 7A-FE) & 2nd Gen 3S-GTE Wiring diagrams. - Great info for people swapping to a 3S-GTE.
5S-FE to 3rdGen 3S-GTE wiring. - Read this to make your swap run a whole lot easier.
The 2nd Gen 3S-GTE Swap. - Read this first if your wanting to swap a 3S-GTE into your ST/AT200.
How to make a Diagnostics switch for your OBDI. - How to make a Diagnostics Switch for your OBDI 3SGTE, 7AFE, 5SFE
How to get your A/C to work with your swap. - Great info, for wiring in A/C with a 2nd Gen 3S-GTE swap.
3S-GTE (ST185, ST205 & ST205 WRC)
(RM398E) 3S-GTE Repair Manual. - The ST205 3rd Gen 3S-GTE engine repair manual. (pdfile)
(RM399E) ST205 Chassis and Body Repair Manual. - The ST205 GT-Four Chassis & body repair manual. (pdfile)
GT-Four New Zealand. - (External link) Has great first hand info. Also see the Technical notes, regarding detailed information about the 3S-GTE and on the WRC edition specifications.
GT-Four UK. - (External Link) Has great info about the GT-Fourís 3S-GTE (ST165, ST185 & ST205), also includes differences between the normal and WRC editions.
GT-4 3S-GTE information (downloadable manuals). - (External Link) Great info site, engines, chassis, wiring & tuning etc.
Repair Manuals for the ST185 3S-GTE. - (External Link) Contains: Engine, chassis and wiring manuals for the ST185 3S-GTE.
3rdGen 3S-GTE part reference. - Quick reference: Part numbers & where to get them from, for 3rdGen 3S-GTE owners.
ST205 and 3SGTE repair tips and info. - Great info for ST205/3S-GTE Owners everywhere
A/C Compressor removal. - How to properly remove the A/C compressor on the 3SGTE. (Has Part numbers for belt and pulley etc)
3S-GTE Cold Weather hesitation solutions. - How to fix cold weather hesitation issues on the 2nd Gen 3S-GTE
ST185 & ST205 3S-GTE differences and similarities. - Gen 2 (ST185) vs. Gen 3 (ST205)
Want to swap a ST215 4thGen 3S-GTE. - Great info if your looking to swap in the ST215 3S-GTE.
ST185 3S-GTE AFM reset. - Great info on, how to set your AFM idle/bypass screw to its factory position.
Replacement exhaust/turbo studs for the 3rdGen 3S-GTE. - Now easier to find.
Traction Issues (Transmissions & LSDís etc)
Converting the MR2 transmission for Celica use. - A great how to, on making the transmission work.
MR2 Transmission Axles. - The "Short" Axel solution thread for the MR2 Transmission in a Celica.
Traction issues and how to cure them. - A Good discussion about traction issues, boost control and traction bars with a 3S-GTE swap, or high power 5S-FTE.
Turbo Accessories (boost controllers, turbo timers etc)
Installing a turbo timer. - Great info, on how to install a Turbo Timer with your alarm
How to clock the 3SGTE Turbo (Wastegate Actuator Bracket). - Great info, on how to fabricate and mount your wastegate actuator when clocking your CT-26.
Easy Knock Detection System for the 3S-GTE. - DIY knock detection system for the 3S-GTE
Getting the right walbro fuel pump. - Great info on choosing the right fuel pump for your swap or turbo setup.
Adding a helper Spring to the wastegate actuator. - How to add a helper spring to your CT series turbo wastgate actuator.
Fuel Injector Size Calculator. - (External Link) A great calculator, to help figure out fuel injector size needed.
Part Database
6GC part database **Currently linked to our basic part list.**
Lo-Fi Version Time is now: August 17th, 2019 - 7:05 AM
