> WTB: Some needed peices for my 3SGE Rebuild, ... anyone parting out a revIII 3S?
post Apr 25, 2012 - 10:07 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
All parts need to be from a 3rd Gen 3SGE/3SGTE:
(1) Upper timing belt cover - FOUND
(2) The alternator tensioner assembly seems to be missing from my engine - this is the 12mm bolt that will tighten the acc belt
(3) *stab in the dark here* - TRD Replica Wing (Hatchback)
(4) Driverside Projector with NO broken tabs. (preferably just the housing, so if you have a wrecked one with tabs intact - I'll take it!!)
I'm sure I will need more as the build progresses, so I will add to this list later, but these are the main ones for now.
Thank you!
Shipped to T4B 2V4 Alberta.
This post has been edited by KAOS: Jun 5, 2012 - 12:33 PM
post Apr 26, 2012 - 7:49 AM
KAOS
Joined Apr 18, '06
(2) Idle pulley assembly from a 3SGE - I think this might be different than on a 3SGTE... not sure however.
This post has been edited by KAOS: Apr 26, 2012 - 7:56 AM
post Apr 26, 2012 - 7:56 AM
KAOS
Joined Apr 18, '06
(3) Ignition Coil Assembly Found! - THANKS HATCHY GT-S!!
This post has been edited by KAOS: Apr 26, 2012 - 11:13 AM
Culpable04
Joined Apr 17, '06
From New Jersey
Part 88440-20120 (PULLEY ASSY, IDLE) was found on the following models:
Date range Model Frames/Options Found in diagram
08/1985-07/1987 TOYOTA CELICA ST16* 87-19: HEATING & AIR CONDITIONING - COMPRESSOR
08/1987-07/1989 TOYOTA CELICA ST16* 87-19: HEATING & AIR CONDITIONING - COMPRESSOR
09/1989-08/1993 TOYOTA CELICA AT180,ST18* 87-19: HEATING & AIR CONDITIONING - COMPRESSOR
is this the ingition coil assy part number ? 90919-02209
if so,
Part 90919-02209 (COIL ASSY, IGNITION) was found on the following models:
09/1993-07/1999 TOYOTA CELICA AT200,ST204 19-01: IGNITION COIL & SPARK PLUG
11/1995-07/2000 TOYOTA RAV4 SXA1* 19-01: IGNITION COIL & SPARK PLUG
post Apr 26, 2012 - 11:10 AM
KAOS
Joined Apr 18, '06
QUOTE (Culpable04 @ Apr 26, 2012 - 6:56 AM) *
if so,
Thanks Culp; I found the Ignition Assembly already.
Just looking for this now:
This post has been edited by KAOS: Apr 26, 2012 - 11:11 AM
post May 1, 2012 - 11:39 AM
sodap0pWRC
Joined May 17, '11
From Calgary
QUOTE (KAOS @ Apr 26, 2012 - 11:10 AM) *
Ask Aaron at Lithia, maybe he can give you some direction
QUOTE (sodap0pWRC @ May 1, 2012 - 11:37 AM) *
I might have a spare, but it would be in storage at my mom and dads. Want to take a drive to look?
94 JDM ST205 WRC#2354 172,000 km (my baby)
94 JDM SW20 GT 151,500km (track car)
91 JDM ST185 RC 106600km (DD)
08 Sea Ray 185 Sport 220-hp MerCruiser® 4.3L MPI , BigAir tower, High5 SS prop. (38hours)
post May 4, 2012 - 2:34 AM
here.. your timing belt cover
http://www.ebay.com/itm/TOYOTA-MR2-CELICA-...=item27c687a40a
post May 7, 2012 - 10:37 PM
KAOS
Joined Apr 18, '06
QUOTE (njccmd2002 @ May 4, 2012 - 1:34 AM) *
Won't fit - doesn't line up properly, that one is probably a Gen 2.
Bump.
Anyone?
post May 8, 2012 - 12:34 PM
KAOS
Joined Apr 18, '06
QUOTE (sodap0pWRC @ May 1, 2012 - 10:39 AM) *
But I think I had a brain-fart here... tongue.gif That bracket is only there if there's no A/C. And I haz A/C on my car - I just left the compressor attached to the lines in the engine bay... laugh.gif rolleyes.gif
post May 18, 2012 - 1:29 AM
KAOS
Joined Apr 18, '06
Adding to the list:
post May 19, 2012 - 7:15 PM
RoyO
Joined Jan 8, '09
From Netherlands
post May 28, 2012 - 3:23 PM
richee3
Joined Jun 29, '08
From Denver
Do you need the whole belt tensioner assembly or just the bolt? Because I have both on my spare beam if the belt tensioner assembly will work for you.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 28, 2012 - 5:34 PM
KAOS
Joined Apr 18, '06
QUOTE (richee3 @ May 28, 2012 - 2:23 PM) *
I'd need the entire assembly. The arm that attaches to the block, the pulley, and the bolts, etc. (and the boldts that attach it to the block! )
Thanks!
post May 28, 2012 - 7:20 PM
richee3
Joined Jun 29, '08
From Denver
The one on my BEAMS looks very very similar. I'll get detailed pictures for you next time I head to my dad's house. Should be early next week if you haven't gotten one before then.
1998 Celica GT-
BEAMS Swapped.
post Jun 1, 2012 - 12:59 AM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (KAOS @ May 8, 2012 - 5:37 AM) *
Bump.
Anyone?
post Jun 5, 2012 - 12:35 PM
KAOS
Joined Apr 18, '06
QUOTE (richee3 @ May 28, 2012 - 6:20 PM) *
Any chance you made it out there yet??
QUOTE (RoyO @ May 31, 2012 - 11:59 PM) *
Bump.
Anyone?
Thanks Roy! You rock!
post Jun 5, 2012 - 2:03 PM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (KAOS @ Jun 5, 2012 - 7:35 PM) *
No problem, money received, I'll ship it out tomorrow. I just left reputation feedback for you biggrin.gif
post May 21, 2014 - 4:05 PM
KAOS
Joined Apr 18, '06
I need the following parts from the diagram:
87240 Heater Switch and all brackets/bolts etc
87246E & 87245A Heater Core Hoses
Please please please please please please. Shipping to 77032.
post May 21, 2014 - 4:11 PM
KAOS
Joined Apr 18, '06
Part #: 33557-33010
This post has been edited by KAOS: May 21, 2014 - 4:12 PM
Lo-Fi Version Time is now: March 20th, 2025 - 11:12 PM
