Enthusiast Joined Aug 29, '16 From asheville nc Currently Offline Reputation: 0 (0%) ![]() |
I have a 97 celica conv and today when I got in, (before I tried to start it) it sounded like the blinker was on. I put key in and nothing. But the blinker noise was still there. All the lights came on inside, and radio worked and antennae went up and down. Anyone???? Thanks
Enthusiast ![]() ![]() Joined Apr 24, '14 From Durham, NC, USA Currently Offline Reputation: 0 (0%) ![]() |
I have a 97 celica conv and today when I got in, (before I tried to start it) it sounded like the blinker was on. I put key in and nothing. But the blinker noise was still there. All the lights came on inside, and radio worked and antennae went up and down. Anyone???? Thanks You posted your question a long time back, so you probably have already figured out what was wrong, but since nobody responded to your questions, I will venture to help, in case it is still needed. BLINKER (A) Was the blinker sound active BEFORE you inserted the key into the ignition switch? (B) Or, did the blinker sound start exactly when you inserted the key, but BEFORE you turned the key to the ON position? © Or, did the blinker sound start exactly when you turned the key to the ON position? (D) Or, did the blinker sound start exactly when you turned the key to the START position? LIGHTS, RADIO, ANTENNA The key switch has three positions, KEY IN, ON, and START. At which position did the lights, radio and antenna become active? And was the blinker sound active at all three switch positions? From your answers, we might be able to determine, from the schematic, what is happening to the blinkers on. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 15, '07 From Tennessee, Podunk Currently Offline Reputation: 52 (100%) ![]() |
if all else fails
![]() -------------------- Learned a lot in 10 years...
2grfe Swapped... Never Satisfied .. always something to do A great civilization is not conquered from without until it has destroyed itself from within. llamaraxing @ Imgur, Ebay and Instagram |
Or the newer GF-5 version. It has a special additive.
Lo-Fi Version | Time is now: April 25th, 2018 - 5:41 AM |
