macavely
May 18, 2004 - 10:00 AM
just wanted to know if anyone has put one of those civic(univarsal) air intakes on there car.. that you get at most major autoparts store, on there 5sfe, and if so how is it working for you?
i'm asking cause i need a new intake hose.. mine is sliced.. but damn toyota i'm not paying 60 bucks for a rubber hose.. i rather just spend 24 and get and aluminum intake..
Einhander
May 18, 2004 - 10:31 AM
I had one on my 7afe for around a year or more, actually works pretty well, only thing i had to do was cut it down (**i got the cold air intake for a civic) and drill the hole for the sensor, Mine came with a hose to attach the sensor, but i didn't trust that and just drilled out the bung for the hose attachment.
Negative
May 18, 2004 - 11:27 AM
I'm using a topspeed intake on my 5S-FE and it's pretty generic. All i had to do was drill and tap a hose fitting for vent to the valve cover and take the sensor and wire it to the strut tower. see my pictures on my profile.
It works extremely well - a major improvement from stock. Uses more gas though.
Punch
May 31, 2004 - 12:06 AM
my intake is off a CRX! I had to do some cutting & hose moving, but other wise no problem. my car runs fine.
macavely
May 31, 2004 - 12:17 AM
i just used a civic intake 92-00 no drilling.. no cutting.. perfect fit.. and great sound.. check out my profile got a pic in there of it..
Akimbo
May 31, 2004 - 12:18 AM
I've got the cheapie universal intake. I can't say that it gave horsepower cuz I can't tell tat without a dyno chart. However I will tell you the sound at idle is nice, and when you're giving the throttle hell the hisssssss is satisfying.
