alex3sgte
May 26, 2004 - 12:16 PM
Hi everyone,Im in the procces of the 3sgte engine swap into my 7afe 1994 celica and I need the original toyota part# for the front,rear,passenger and driver motor mounts from 1994 toyota celica GT-S with 5sfe engine,because thath the engine mounts that Im goona use.Please part#s for all the 4 mounts.
celicaracer18
May 31, 2004 - 3:50 PM
are these the best mounts for the swap, i'm doing it too
May 31, 2004 - 6:42 PM
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74330 RH
Digndoug
May 31, 2004 - 7:20 PM
I have a question, nt to steal your thread.. But The motor i bought has the mounts on it.. Its the 3s-ge .. not the beams.. but thopse mounts should work for my st? right? Thanks
titaniumkid
Jun 1, 2004 - 2:53 AM
QUOTE (Digndoug @ Jun 1, 2004 - 12:20 AM) |
I have a question, nt to steal your thread.. But The motor i bought has the mounts on it.. Its the 3s-ge .. not the beams.. but thopse mounts should work for my st? right? Thanks |
im pretty sure as long as you have 94-99 gt motor mounts, that block will mount up
celicaracer18
Jun 2, 2004 - 7:26 PM
QUOTE (presure2 @ May 31, 2004 - 11:42 PM) |
12360-74030 front 12371-74410 rear 12372-74450 LH 12362-74330 RH |
the toyota deal said one of these is wrong
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74430 RH
it is going to cost over 300 for all of these from the dealer
where else should i try to get these
i tried local auto parts stores but those numbers didn't transfer into anything
Doge
Jun 2, 2004 - 7:37 PM
Two words....Junkyard Celica =)
Punch
Jun 3, 2004 - 8:20 PM
you can get urathene mounts, go to your local performance shop.
they can used the old mount and pop the urathene insert in.
Jun 4, 2004 - 7:48 AM
12360-74030 front
12371-74410 rear
12372-74450 LH
12362-74430 RH
do you know which one?
12362-74430 RH this is the wrong one...the right # is 12362-74330
sphinx
Jun 4, 2004 - 11:00 AM
it doesn't matter if you have a ST or a GT.
The FRONT and BACK mounts are identicle. You can use your existing ST mounts. The only thing you have to buy are all 4 Motor Mount Brackets and the Driver and Passenger side mounts for a GT. That's less money you have to spend.
celicaracer18
Jun 6, 2004 - 10:18 PM
QUOTE (presure2 @ Jun 4, 2004 - 12:48 PM) |
12360-74030 front 12371-74410 rear 12372-74450 LH 12362-74430 RH do you know which one? 12362-74430 RH this is the wrong one...the right # is 12362-74330 |
they told me 12362-74330 RH is wrong that its 12362-74430 and it $197
ok so all i need is driver and passenger side mounts
