frotou
Jun 24, 2004 - 7:03 PM
Need to complete the exhaust and some wiring , but it started ! Here are the last pics...
The engine
Custom wiring
Part of fmic piping
More later ...
Claude
macavely
Jun 24, 2004 - 7:09 PM
and Mac bows down...
sinner96ST
Jun 24, 2004 - 7:16 PM
never seen a set up like that, very clean!
dstrbcelica
Jun 24, 2004 - 7:35 PM
omfg..that's crazy.
Jeremy1210
Jun 24, 2004 - 8:12 PM
Looks really clean and sharp. Good job. What head is that?
macavely
Jun 24, 2004 - 8:13 PM
looks like the head off a 4age I'm i right??
Jen
Jun 24, 2004 - 8:42 PM
VERY nice. I'm impressed.
S_C_M
Jun 24, 2004 - 9:27 PM
Very nice, but it seems a shame to put all that effort into the setup and still use that flapper-door AFM. Still, very impressive work on the 7AG. Did you build up the bottom end at all?
If you don't mind me asking, what solution did you chose for the water pump? The builds I've seen ended up using the 4AGE pump with a lengthened coolant pipe.
frotou
Jun 24, 2004 - 9:42 PM
I know that the afm is not the best for this setup but it supposed to be not too restrictive until 260-280 hp range. I'm not plan to run high boost before next year ; 8-10 lbs for this year. The bottom received oem 4agze piston, polished 7afe rods and crank , all balanced . I still belived that the oem rods can take 16-18 lbs of boost with right tunning ... we will see. For the water pump it's the 7afe pump with the metal hose from 4age cut and couple with a hose coolant .
The 316 ss manifold
My car before the ultime paint job
Claude
95STHATCH
Jun 24, 2004 - 10:06 PM
I couldn't believe what I was seeing when I saw these pics. That has got to be the most insane engine work in a celica I've ever seen! Did you do all this work yourself? You should be contacting some magazines right now.
Jun 24, 2004 - 10:37 PM
That's like a work of art. If you don't mind me asking, how much is this whole thing costing ?
Jun 24, 2004 - 11:43 PM
yea, how much is this costing, and some info please,
4age head?
custom exhaust manifold?
t3 turbo?
how did you mate the head and the block?
FallenHero
Jun 24, 2004 - 11:46 PM
what radiator is that? I didn't think they made one for a celica...
jgreening
Jun 25, 2004 - 12:49 AM
beautiful. Nice work.
Kwanza26
Jun 25, 2004 - 1:04 AM
Again... awesome job. I'll probably do this eventually myself... ;]
97sccelica
Jun 25, 2004 - 2:34 AM
you rule
that is a prime example of a true import tuner.
sinner96ST
Jun 25, 2004 - 2:56 AM
yeah, good job on a unique hybrid.
we want video / dyno / slips ! keep us updated. this is an awesome ride.. should be front page material.
S_C_M
Jun 25, 2004 - 9:59 AM
QUOTE (frotou @ Jun 25, 2004 - 2:42 AM) |
The bottom received oem 4agze piston, polished 7afe rods and crank , all balanced . I still belived that the oem rods can take 16-18 lbs of boost with right tunning ... we will see. For the water pump it's the 7afe pump with the metal hose from 4age cut and couple with a hose coolant . |
I agree with you that the 7A bottom end is stronger than it's given credit for if it's assembled properly. I'm sure you will be fine at your initial boost levels, and probably further; there's just not a lot of data on 7A parts past ~12psi that I've seen. It certainly sounds and looks like you're doing things right. Thanks for the water pump information also.
ghostdog
Jun 25, 2004 - 10:17 AM
awesome setup.
THIS IS EXACTLY WHAT THIS SITE SHOULD BE ABOUT
frotou
Jun 25, 2004 - 10:19 AM
The 4age head bolt direct on the block with the 4age head gasket , I use arp head bolt for an 4age too . But all the others things don't bolt togheter ; coolant system , intake , wiring , sensor , ecu are from 4age big port fwd . There are custom bracket for alternator and power stearing .
For the radiator is from integra 94+
with custom bracket on top and bracket under are replace .
The turbo is a t3 super60 from turbonetics buy on ebay.
For the manifold I have the flange for the head and for the turbo (t3), 12 elbows (11 guage 316 ss) and 48 " of piping of same material. With one of my friend (he's a welder) we place the two flange in the car and join them with an heavy plate of steel and started the fabrication of each runner outside the car.
I`ll keep you guys updated .
Claude
Jun 25, 2004 - 11:42 AM
dude, awesome info, i hope your writing everything down as your doin this so that you'll have a full write up when your done
BigEdge169
Jun 26, 2004 - 4:03 PM
That looks incredible and is inspiration to say the least.
Drocay
Jun 26, 2004 - 4:13 PM
it looks amazing man.
celicaofsin
Jun 29, 2004 - 6:50 AM
No words can amount to what you have done... That is just beautiful, I hope thier will be a full write up!? As I am just starting my build up thihs is the best inspiration I could ever ask for... WOW!
frotou
Jun 29, 2004 - 1:35 PM
Yes I'm thinking of a full write up with all the costs ; maybe in the last of summer or this winter in the section completed engine swap .
nik
Jun 29, 2004 - 1:38 PM
...... wow nice
drdos
Jun 29, 2004 - 1:39 PM
hmm what kindof hp numbers you looking to achive?
Jun 29, 2004 - 1:48 PM
Wow, That's just insane! That's so incredibly sweet! Very, very nice work! Everything looks excellent!
reborn0323
Jun 30, 2004 - 5:44 AM
definitely looking forward to the write up - i've been researching engine swaps and the like
rlan214
Jul 5, 2004 - 10:51 AM
how's the hybrid doing ?
frotou
Jul 6, 2004 - 11:27 AM
The car is in garage for the paint and the guy who painted it for me is in vacation for two weeks , update next week ...
celicarocker
Jul 6, 2004 - 1:18 PM
awesome job man.... i remember when you started this project, and you posted pics of the all blue block, people were like "thats dumb" now everyones like
frotou
Sep 3, 2004 - 11:50 AM
WannabeGT4
Sep 3, 2004 - 11:55 AM
daaaaaaaaaaaaaaaaaamn!!!!!!!!!!
Sep 3, 2004 - 11:56 AM
WOW! So amazing! Your car looks great!
Is the car pretty quick? Have you taken it to the track or gotten it dynoed yet?
sphinx
Sep 3, 2004 - 11:57 AM
holy fu**ing sh**t. That's amazing.
Jaws4God
Sep 3, 2004 - 12:03 PM
all I can say is...............wow
x_itchy_b_x
Sep 3, 2004 - 12:07 PM
good goly gosh. DAM thats the nicest celica. FEatured RIDE!!!!! voted. wow.
hs2g
Sep 3, 2004 - 12:11 PM
Your car is just amazing. I love the paint. Keep up the good work, and how much power is that setup making?
blkGT
Sep 3, 2004 - 12:19 PM
hey frotou, can u repost the pics u posted months ago. i cant seem to find them.
frotou
Sep 3, 2004 - 1:16 PM
Here are the pics from the start :
7agte now startedFor the power of my setup I still don`t know the potential of my hybrid...It`s like a kind of surprise for next year because my car is in break in for a couple of month...(Also it is stored for winter from november to april so ...)
Claude
jayi12-15psi
Sep 3, 2004 - 1:37 PM
holy ****
CheesyLobster
Sep 3, 2004 - 5:21 PM
SSSSSSSSSOOOOOOOOO
AAAAAAAWWWWWSSSSSSSSOOOOOOOMMMMMMEEEEEE!!!!!!!!!!!!!!!!!!!
Never seen anything like that! Amazing.
Jen
Sep 3, 2004 - 5:35 PM
Oh.. my.. god..
That is absolutely.. incredible.
RedSunCelica
Sep 3, 2004 - 5:52 PM
first time seeing this thread ................... damn got to change pants
redtcel
Sep 3, 2004 - 6:46 PM
QUOTE (RedSunCelica @ Sep 3, 2004 - 10:52 PM) |
first time seeing this thread ................... damn got to change pants |
i second that, i just had multiple orgasms..... oh man... here comes another one....
Anub1s
Sep 3, 2004 - 7:01 PM
That is one of the hottest things I have ever seen! Way to go.
CheesyLobster
Sep 3, 2004 - 8:48 PM
How do you vote to feature a ride?
vangSTa_celica
Sep 3, 2004 - 9:09 PM
i just jizzed my pants...that is so hot
rza619
Sep 3, 2004 - 10:25 PM
was wondering what kind of wing is that i know its a type z lip kit but what wing is that?
