Yota
Jun 28, 2004 - 2:30 AM
I am doing a 3S-GTE swap into my ST. I don't know what transmission I should use. I've been told to go with either :
5SFE
V6 camry/Solara
MR2 Turbo
Which transmission would you guys suggest I use? Whish would be the strongest to use and most reliable. What type of work would need to go into building it up also?
Thanks guys!
racingmcfly
Jun 28, 2004 - 2:40 AM
Don't know much about the v6 box, but the MR2 box was originally designed to go with that engine, so its all gonna be geared better for that engine, plus i believe you get a limited slip diff and equal length driveshafts to reduce torque steer, which will be a great help with 250bhp going through the front wheels!
Yota
Jun 28, 2004 - 2:56 AM
Ok, that makes sense. Where can you go to buy just a transmission?
reborn0323
Jun 28, 2004 - 4:10 AM
QUOTE (racingmcfly @ Jun 28, 2004 - 1:40 AM) |
Don't know much about the v6 box, but the MR2 box was originally designed to go with that engine, so its all gonna be geared better for that engine, plus i believe you get a limited slip diff and equal length driveshafts to reduce torque steer, which will be a great help with 250bhp going through the front wheels! |
ok i've been thinking of doing the swap and have been researching what i need too and i have one question about getting a mr2 clip
wouldn't the mr2 being a mid body engine rear wheel drive format affect the tranny, diff, driveshaft setup??
Kwanza26
Jun 28, 2004 - 11:58 AM
QUOTE (reborn0323 @ Jun 28, 2004 - 9:10 AM) |
wouldn't the mr2 being a mid body engine rear wheel drive format affect the tranny, diff, driveshaft setup?? |
No...
lantz2121
Jun 29, 2004 - 11:27 PM
I also am performing a 3g 3sgte swap into my celica I have heard that you can use the gt-4 gearbox by removing the rear trans case and fabricating a plate to cover it. It this recomended?
Yota
Jun 29, 2004 - 11:39 PM
Where can I find an MR2 turbo transmission?
jgreening
Jun 30, 2004 - 6:15 AM
Jun 30, 2004 - 10:15 AM
Get the MR2T.
Ebay. The LSD's will be twice as expensive, and twice as rare. The regular ones will do just fine.
celicaracer18
Jun 30, 2004 - 5:48 PM
when i ordered my engine, i got it from renewed import and they buy clips from japan and ship you what ever you need to cut down on shipping, i got the MR2 3sgte, i upgraded there listed engine kit to one with all the extras you need for that swap aswell as a lsd tranny, the upgraded tranny cost me an extra 300.
Jul 1, 2004 - 8:19 AM
thats well worth it.
I'm currently looking for a SW20 tranny, If i find a nice one without LSD i'll get that, and then the LSD axles and then see if i cant source some alltrac outters 1/2 shafts.
