Full Version: t3
pxcr440
i am turboing and i am looking into a t3 , i plan to run a max of 8psi and i was wondering how a t3 will work ,
Fox-N-It2
A T3 would work but I believe that it would be too small for a 2.2L 16v. I'd go with a T3/T4 hybrid or a GT28RS.
pxcr440
thats what i was thinking , but some say the t3/t4 is to much cause it designed for high power cars i thoughe, i also want the quik spool up of the t3
Fox-N-It2
A T3 super 60 will probably be your best choice then. It wont have as much in the upper RPMs though.
Considering alot of ppl use the CT26 the T3 should do u fine.
hyp3rk1d
shid
T3 will be perfect if you're not looking for high high horsepower numbers. Check it's compressor chart and make sure it matches ur interests
pxcr440
all i want is a fast spool for about 8 pounds of boost ,
shid
You'll get it
hyp3rk1d
Fast spool with 8lbs, honestly i'd recommend a CT26. Find a JDM one with a ceramic wheel which will enable faster spool up and stock pressure is 8 so ur good to go, and then you can even upgrade the trim to 45 - 50.
shid
QUOTE (Supersprynt @ Jul 28, 2004 - 4:16 PM)
Cheaper too
nik
hyp3rk1d
get the t3 with a 45 trim..
