Full Version: 3sgte Cut Wire Harness
eggman40
IF YOU WANT TO USE A CUT WIRE HARNESS FOR A 3SGTE, WHAT STEPS ARE NEEDED TO MAKE IT FIT AND WORK PROPERLY IN A 94 CELICA ST?
CAN WIRING HARNESSES BE PURCHASED SEPERATLY? A WEBSITE MAYBE?
You need the plugs on the end, cuz you need to use the st185 ecu...try ebay.
Punch
what exactly are you trying to do???
in a worse case, you can get a engine bay harness from toyota for about 400
QUOTE (presure2 @ Oct 5, 2004 - 4:02 AM)
thats not that bad...i thought they would cost more then that. but the question still remains...
HOW DO HARNESS U MAKE DO FIT TO CAR CELICA!
Punch
QUOTE (eggman40 @ Oct 4, 2004 - 9:16 PM)
there is a Mr2 harness on e-bay!
DamDirtyApes
ever hear of the caps lock butten... just move ur pinkey 2 mm and press it. all caps is very bad interent ettiquite
