pxcr440
Oct 21, 2004 - 11:32 PM
i am out of ideas, i got the new turbo on my 5s and it blow a lttle oil when i rev it up , and when connected it smokes when i let off the gas when revend higher, i just reddit my drain with 3/4 line and have a control valve on the inlet lien and it still leaks a little ,, the turbo has zero shaft playu what so ever and doesnt smoke when idleing only whe given a good amount of gas , whats is the problem could fit be that my drain is stillnot workig corecctly or what , or is the drain to low in the pan i didnt put the drain in so i t might be
recneps
Oct 22, 2004 - 8:05 AM
did you use a 3sgte oil pan or the stock 5s one and drill your line into it.
FallenHero
Oct 22, 2004 - 11:00 AM
something somewhere is either
A: applying pressure to your valve cover forcing oil into the compression chamber,
OR
B: the center section on your turbo has a leak.
My vote is for the latter.
Fox-N-It2
Oct 22, 2004 - 12:35 PM
Your drain line should be mounted on the pan as high as possible. It work via gravity.
Im guessing you have a restrictor in the oil feed to make sure your oil pressure doesnt blow your seals out right?
pxcr440
Oct 22, 2004 - 9:37 PM
yah its as high as possible and its resturcted via presure regukator and i cant go any lower safely
FallenHero
Oct 23, 2004 - 12:26 AM
Well,,,, you could always run the return line to a vented catch can and THEN to the oil pan. That would Definitly clear up the problem if that is indeed the problem. It could be done for less than $100 and would look hella nice.
