tigernate29
Nov 1, 2004 - 9:55 AM
I bought a brand new turbo off of E-bay. 57 trim compressor, 50AR Exhaust housing, 63 AR compressor housing, internal wastegate set to 10 lbs. Is this too big for a 7afe? All I can get out of it so far is about 4 lbs. of boost. I will post pictures of my setup in the next day or too. Seems to spool up kind of slow.
nik
Nov 1, 2004 - 10:28 AM
pics
shid
Nov 1, 2004 - 11:07 AM
Yeah, sounds way too big, what kind of turbo is it?
tigernate29
Nov 1, 2004 - 11:59 AM
It's a t3/t4 E. Give me a day or 2 to get the pictures developed. If it is too big, then is there any way to reduce the turbo lag?
tigernate29
Nov 1, 2004 - 12:01 PM
turboHere's a link to the turbo I bought.
97sccelica
Nov 1, 2004 - 12:42 PM
yea
way too big
you got yourself a turbo that makes 500+ AWHP in a awd DSM.
nik
Nov 1, 2004 - 1:32 PM
QUOTE (tigernate29 @ Nov 1, 2004 - 10:01 AM) |
turbo
Here's a link to the turbo I bought. |
my turbo is from down2turbo e-mail him tell them your situation and see if they can swap you for a turbo (t3) that you need or a alot smaller t3t4
shid
Nov 1, 2004 - 1:42 PM
Yeah, the smaller t3/t4 turbos can be alright on a 7afe; but your trim size/compressor housing etc is way too huge
tigernate29
Nov 1, 2004 - 6:06 PM
Thanks everyone. Hey Nik, can you E-mail me down2turbo's E-mail address so I can try and work this problem out? Thanks.
nik
Nov 1, 2004 - 6:11 PM
QUOTE (tigernate29 @ Nov 1, 2004 - 4:06 PM) |
Thanks everyone. Hey Nik, can you E-mail me down2turbo's E-mail address so I can try and work this problem out? Thanks. |
PM sent
DamDirtyApes
Nov 1, 2004 - 6:45 PM
u dont research turbos before u buy one....... why would u spend a couple hundred dollars wihtout knowing if it will work out good
tigernate29
Nov 1, 2004 - 10:03 PM
QUOTE (DamDirtyApes @ Nov 1, 2004 - 11:45 PM) |
u dont research turbos before u buy one....... why would u spend a couple hundred dollars wihtout knowing if it will work out good |
I actually did research. I checked with my local speed shop who told me to get the size that I did. I then bought one from E-bay that was the size that they suggested. I have been planning this for months and months, and it came down to bad advicefrom my local speed shop. I'm not a professional, but I relied on the wrong pro's. People, beware and always get a second opinion!
DamDirtyApes
Nov 1, 2004 - 10:11 PM
did u put this in yourself?
woode87
Nov 1, 2004 - 10:23 PM
hahahah, this is a funny topic. i posted it at a few other car forums and they laughed
spunky393
Nov 1, 2004 - 10:53 PM
Can someone explain the water cooled and oiled cooled difference. Also, i think i know, but i would like to know the advantages of the ball bearing and to normal (what is normal) Just for my big head knowledge base
shid
Nov 1, 2004 - 11:13 PM
Ball bearings basically mean the turbo spools without friction being an issue. Normal has slight friction- so slowly spool up time and more turbo lag
water cooled means the turbo is cooled with water; oil is cooled with oil
I'm not sure what's required out of a water cooled setup (what lines you have to run)
Don't get to read:
http://www.6gc.net/forums/index.php?showtopic=5574and all the articles it links to. Yes it's for the 5sfe, but it spends a lot of time on turbo principals you need to understand.. I really should finish my part..
