Full Version: 4agze swap
iceshrdr
I'm swapping a 4agze engine into my 1997 st celica. If anyone has info on this swap that would be great, Thanks.
search button......its been tried and not completed yet to date
iceshrdr
are there any other engines other than the 3s-gte that are worth swapping in? Replacing the 7afe engine.
recneps
umm its all a matter of opinion. theres a sticky aqt the top of this page.
Dr_Tweak
I can swap a 4AGZE into your Celica no problem, and yes that will be a worthy engine to swap in, not to mention easier than a 3SGTE (in the ST, the engine mounts line right up). Also you will likely get the LSD tranny with it if you get a clip from a Levin GTZ, and the engine is easy to turbocharge since it's already built for F/I.
joshua@phoenixtuning.com
