Full Version: 3sgte from st 7afe
powerkor
ST 7afe (1997) to a 3s-gte...
est. costs for this to be done please?
(labor not included)
SlowCelica94
Did you use the search button or read the stickies at the top of the page?
member almost a year now and your asking this, tisk tisk.
powerkor
eh, ive read everything atleast once... but i didnt have money a year ago... so i guess i just wanted the answer.. meh.. ill check it out.
2k
powerkor
i basically plan on taking it to a shop to have the entire thing done right there, i figure ill save on costs this way, rather than taking it to multiple shops.
i plan on replacing upgrading the following:
suspension - coilovers, brakes, shoes and rotors, camber kit
tires and wheels - conni's extreme contact , rims not picked
engine - 7afe to 3s-gte ( front clip shipped to shop )
custom enclosure for 18" kicker sub and space for nos can
nos?? - its a possibility... but i think ill be happy with a swap for now
body kit and paint job ( frontend to look like gt4, possibily metallic green )
other minor details
i've already gotten tips on wheels.
need some advice from people who have done suspension (what brands aren't crap) etc...
need some advice on the engine... all i need is front clip or do i have to order more parts?
in the mean time, im gonna be researching this forum more and other sites.
Sev408
QUOTE (powerkor @ Nov 10, 2004 - 4:07 PM)
other minor details
lets see,
suspension: Tein Coilovers roughly $800 i believe, Brembo cross drilled brake rotors and green stuff brake pads
rims what ever you want i would go with an 17in x 8in width though
NO NOS, its not needed its like 75 bucks a fill and you will have a damn turbo on your car, use it not a damn bottle
engine i would do a basic overhaul, spark plugs/ wires, replace your basics like you would with any used car.
buy a front clip with uncut wireing harness.
u need MR2 TUrbo transmission or GT transmission
need GT shifter cables to swap over on the MR2
custom axles i believe
front mount intercooler with custom piping
custom exhaust piping will be needed
powerkor
Custom axles... how much does that run? Sounds tricky too.
recneps
if you get a mr2 rear clip you should be fine using the mr2 axles.
the only problem where you come into needing custom axle stuff is using a lsd tranny and a non lsd axle, like if you had a gt and got a mr2 transmission.
this is because the half shafts for the lsd tranny are shorter than the ones for a non lsd tranny.
someone correct me if im wrong.
