thedevilmaycrie
Nov 10, 2004 - 6:55 PM
ok guys heres my prob. i installed a Greddy Prefec B into my car today.... As soon as i react .2 bar the engine cuts off till i let off the gas .... any suggestions????
-DMC
Nov 10, 2004 - 8:19 PM
sounds like you are hitting fuel cut.
did you disconnect and plug the Tvis? you can not correctly control the boost with that line still hooked up. im not sure what .2 bar is in psi. but stock fuel cut should be around 12-16psi depending on what year your motor is.
Consynx
Nov 10, 2004 - 8:23 PM
.2 bar is equivalent to about 3psi
it's roughly 15psi for every bar
Nov 10, 2004 - 8:24 PM
CEL coming on?
Nov 10, 2004 - 8:25 PM
yeah pull the CEL codes and see what they tell u.
thedevilmaycrie
Nov 10, 2004 - 8:52 PM
problem solved thanx supersprynt
Nov 10, 2004 - 9:20 PM
so, what was it?
Consynx
Nov 10, 2004 - 10:04 PM
im curious too!
