Full Version: 7afe trans choices
Skate4mindgame
Are there any other trans's that can be used with the 7afe engine, such as any of the other A series engines that are FWD?
DustyBurns30
the e51 trans from the jdm levin gtz will bolt up. the ae101 e51 comes with factory lsd and i believe the stock axles will work with no modification, although these axles are almost impossible to find unless they come with the tranny.
Skate4mindgame
Ah ok because i just got an 7afe and plan on doing the 7agte conversion as soon i get some more cash, and im not sure if the stock 7afe trans will be able to hold the extra power.
FallenHero
yes, it will. wink.gif it's been done before with no problems. Engines go before the trannys probably 50 to 1. wink.gif
DustyBurns30
yeah, your stocker will be fine for a decent turbo setup.
