Full Version: gear-box oil
maikl
i've changed my clutch one week ago and i've changed my gear-box oil as well and put a full synthetic and from that time i have proplem shifting the gears especialy when the car is cold frown.gif i'm pretty sure that is the oil wich oil do you use in your gear-box? confused.gif
duga10
it should say in your car manual,
it is usually red in colour (so it can be easily identified)
It will even say on it gear or transmission oil/lubricantation.
it allso comes in for manual or automatic.
bufferdan
Try to get some Pennzoil Synchromesh. That stuff works wonders in the cold and should eliminate all grinding.
maikl
thank's
liquor
I used Red Line Oil's MTL and it worked well for me and we have temperatures below -20 here!!!
Junior
make sure you guys are using gear oil in manual tranny's and not tranny fluid.
Mynzeyes
both the US ST and GT use 75W-90, GL-4 or GL-5 rating. i'm not sure about the SS-III though. frown.gif.
