Full Version: Which bov
urbandork
What are some tips when looking for a bov? ill be running about 8 to 10 psi tops.
Mr_E
QUOTE(urbandork @ Feb 21, 2005 - 1:36 PM)
[right][snapback]248523[/snapback][/right]
Tips?
Fits on the car. Doesn't leak boost.
If you have a MAF, the ECU might not like you dumping to atmosphere.
Anub1s
Definitely get a recirculating BOV. It helps keep the engine running with a good mixture instead of running to rich for a moment. Bad things can happen that way.
urbandork
are some companies better then others and what would be an example of a recirculating bov. Im not to fimilar with these things.
97sccelica
QUOTE(Anub1s @ Feb 21, 2005 - 1:11 PM)
[right][snapback]248555[/snapback][/right]
that "problem" is hyped up alot. looking at the wideband on my car, it doesnt get overly rich.
sure, the bov lets off metered air, but the throttle body is closed. so its not like the air was going into the engine
now if the BOV leaks on a MAS/AFM car, that causes a problem.
my hks bov is great!
SlowCelica94
HKS SSQV
Biltz
TurboXS RFL
97sccelica
QUOTE(SlowCelica94 @ Feb 21, 2005 - 7:32 PM)
HKS SSQV
Biltz
TurboXS RFL
[right][snapback]248679[/snapback][/right]
RFL is crap.
it only works well at full throttle
then it randomly opens at part throttle/boost
its very loud tho, i might put it on my WRX just to see how loud it is at 17psi
SlowCelica94
If it's crap, why would you consider using it? That doesn't make sense. I haven't heard any complaints w/ the rfl
97sccelica
QUOTE(SlowCelica94 @ Feb 21, 2005 - 7:37 PM)
[right][snapback]248682[/snapback][/right]
i already have it, and i tried it on my car with the stock tmic worked ok then but when i went fmic i noticed the part throttle/boost problem within 2 miles of driving and took it off.
and i gave a reason for trying it
it was to see how loud it would be now with more boost and the volume of a FMIC setup
QUOTE(Anub1s @ Feb 21, 2005 - 4:11 PM)
Rich for a moment causes what problems? I've been using my bov open atmosphere for over a year without problems.
SSQV gets my vote. Cant leak.
when i heard the SSQV on lagos's car
at ATL HIN
i didn't like it much
its more of a HIGH pitched wistle for an instance then the
pssssst
the "sound" of the ssqv is easily adjustable with the interchangable inserts they sell...they go for about 14$ on ebay..im actually thinking about getting the purple insert to have more of a whoosh than the loud whistle, im sure the sound of the silver insert will get old quick..lol
my vote
HKS SSQV
I may get an insert also, Idk yet because I do really like the stock sound, but its noice to have a change.
nik
greddy type S
or you can just take the center piece totally out and just get a pssst. more along the lines of a truck bov.
also the sound will change depending on how you have the screw adjusted.
i have noticed that sometimes my car does bog down a little between shifts and i even get some mild backfire. i think it depends on how large your IC and piping is. Supersprynt, reports no problems with his topmount IC, but i notced mine bog down slightly with the fmic and all the extra piping i have.
x_itchy_b_x
i have a cheap "monza" one off ebay. its basicly a turboxs knock off but not the rfl.
it would leak at 10psi so i packed the spring more with washers now its fine. it has a Very large woooosh sound. (like a huge toilet flushing tongue.gif ) hah not that bad.
my friend has the RFL on his 3000gt VR4 its really loud but i was talking to the guy at a local tunning shop and he says the rod inside that BOV is really weak and likes to break. i dont know if thats true or not.
My other friend with a WRX really loves his HKS ssqv. i like it but he didnt hook up the vaccum line to it so when the BOV goes off its more of a lfuttering high pitch whistle. very cool. but i dont know if its that great for the turbo.
If i was going to upgrade id like to get the APEXI dual drive. sounds very nice on the gst i heard it on.
Mr_E
If I was to replace the stock one I'd probably go for a HKS SSQV.
initialdrift55
Im with nik the Greddy bov but nik you might want to check out there new one ive heard its bad a$$....guys should look into it its the Greddy type RS
i love the wosh type best
