Full Version: Intake Temp Sensor
tomazws
When I was uninstalling the air filter box, there's this lil plug that you could just pull out. That's the temp sensor right?
What will happen if I forgot to drill a hole on my cold air intake to shove this sensor thru the tube?
Many thanks!
Anub1s
Your car will run right? biggrin.gif When I had my Celica I put in a cold air intake and drilled the whole for it and just used some silicone goop to hold it in.
CheesyLobster
Yep, thats the thermometer. You definately need it for your car to run efficiently. Just drill a hole in your CAI (I think I used 1/2 inch?) Just don't make the hole to big or it will move around. To hold it in place, use the little rubber thing that was holding it in place on the stock airbox.
pimped6gen
oh god i just relized when i put in my short ram in I left my temp sensor just hanging in my engine bay for the past 4 months or so...did this hurt anything? lol...woops!
Kwanza26
QUOTE(pimped6gen @ Feb 27, 2005 - 5:16 PM)
[right][snapback]250750[/snapback][/right]
it doesn't really hurt anything... your fuel maps would just not be as accurate...
pimped6gen
QUOTE(Kwanza26 @ Feb 27, 2005 - 5:37 PM)
[right][snapback]250754[/snapback][/right]
so my it will hurt my mpg? or what?
urbandork
To clear things up....
If you leave ur temp sensor just hanging under the hood. It will actually be reading hotter air then it would if it was in the stock air box. This sends rong data to the cars comps and i believe less fuel to the cylinders.
Basically while your intaking cold air (short rams not included) you comp is being told that its actually intaking WAYY hotter air. This is bad and in a sence defeats the whole idea of CAI.
Best solution is drill a whole and use the rubber peice thats on the stock airbox to hold the senor in the pipes.
If you look at teh CAI how to there are pix.
Another thing to note are those little resistors ppl sell on ebay promissing HP gains. What this does is trick ur engine into thinking its getting really cold air and thus thow more feul into the cylinders. While this isnt the best thing for the car it does show the importance of having the temp sensor actually sensoring the air that goes into the engine rather then WAY hot air thats in the engine bay.
pimped6gen
wow thanks for the replies guy BUT...
what if i had the sensor down under the filter so its actually sensing colder air while i am driving...that may be why my tempertue on the gauges read just a little bit above the C on the gauge....could this be a VERY cheap way to get "cold air"??? or is the not good?
Kwanza26
The ecu doesn't rely completely on that sensor to calculate fuel maps... so its effects aren't major. The only time it can adversely affect the ecu, is when the sensor dies or is jumped (like those ebay power chips)...
pimped6gen
I see so my temperture gauge whithin my car does not 100 percent rely on that sensor? so then is there another reason why when i am driving my temperature guage goes down to almost the C and when i am stopped for long periods of time it goes up about half way?
mikew04
The temp guage measures coolant tempurature.
Kwanza26
QUOTE(pimped6gen @ Feb 27, 2005 - 9:48 PM)
[right][snapback]250827[/snapback][/right]
The temp gauge in your car is measured from the Coolant Temp Sensor... not the intake air temp sensor.
pimped6gen
QUOTE(mikew04 @ Feb 27, 2005 - 10:00 PM)
[right][snapback]250831[/snapback][/right]
so check my coolant levels?...so i am confused...please tell me if i am right or wrong..i am trying to understan this, the sensor that goes into my intake has nothing to do with the temp gauge in my car....its only there to let the ecu know what tempurature air is entering into my intake?
Kwanza26
QUOTE(pimped6gen @ Feb 27, 2005 - 10:04 PM)
[right][snapback]250833[/snapback][/right]
Yes...
pimped6gen
ok now that we got that all cleared up...i was wondering why my guage in my car is right above the C when i am driving but sometimes it just randomly goes up about half way while i am driving....and when i am stopped it ALWAYS goes up to half way...is tthere something wrong w/ my coolant? or is there something else that could be the problem?
urbandork
sticky thermostat?? what do you guys think??
Is ur fan going on?
are ur collant levels good?
just shottin ideas out?
pimped6gen
thanks urbandork I can check on those possibilities!
Any more things that could be wrong?
urbandork
This makes me wonder. My operating temp puts the needle on the temp gauge at its half way point. Is this normal or should i be worried? i think its normal right?
mikew04
yah, thats where it should be
tomazws
I've drilled a hole and plugged that thing in...
Damn, that's a huge hole. I neeed to buy more drills..
urbandork
i used a hole saw. pix of mine are in the cai how to.
slim75
just a quick question I lost the little rubber piece that holds the intake temp sensor from my stock air box were I could get a new one.
urbandork
junk yard? toyota dealer ship? maybe look at the washers and stuff at ur local hardware stor and glue like 3 together or something.
rocknroll
hi im a new member my toyota celica mreg has a problem with the temperture gauge and the middle heater the gauge takes ages to rise and only rises not even half way thn drops and stays my two side heaters work and av checkd hoses to the radiator and thr fine warm and soft can u please help
QUOTE (rocknroll @ Dec 16, 2010 - 12:23 PM) *
You need a new temperature gauge sensor.
mkernz22
I know this thread is really old, but during the summer (and in the winter), my temperature gauge has been at the exact same spot after the engine warms up. It's just over half way between the C and Normal, is that alright?
