BBoYRuGGeD
Mar 24, 2005 - 8:04 PM
hey guys... someone please enlighten me!!! say i was gunna do the camry v6/solara tranny swap... i know i need the all-trac axles and the mr2t axles correct? my question is which all-trac axle CAN i use? st165, st185, or st205 axles??? or are they all the same???
im a very confused individual!
BBoY
ZoomZoom
Mar 25, 2005 - 10:07 AM
I know the st185 will work, but can somebody tell us if the st205 will work.
Im assuming that the st205 axles will work for the 6th gen. Please somebody correct me if I'm wrong.
Thanks,
QUOTE(BBoYRuGGeD @ Mar 25, 2005 - 1:04 AM)
BBoY
[right][snapback]261961[/snapback][/right]
ZoomZoom
Mar 28, 2005 - 8:41 AM
can somebody please answer this question !!!
I need this info as well.
will the st205 axles will work for the e153 tranny swap?
Thanks for the help...
Mar 28, 2005 - 10:32 AM
You need hybrid axles no matter what. You can use St205 outta 1/2 shafts and MR2 inners or Solara inners, depending on what tranny.
ZoomZoom
Mar 28, 2005 - 11:41 AM
so the st205 outer shafts would work for the hybrid tranny
thats all I need to know
thanks supersprynt...
sphinx
Mar 28, 2005 - 12:38 PM
I'm using Camry outer shafts and MR2 inner shafts, and they work great.
So either way will work.
Mar 28, 2005 - 2:47 PM
Sphinx whst kinda information and or knowledge do you have on the mounting of your E153. I am doing this hopefully within the month and theres little spoken of this even though I know 3 ppl who have it here.
BBoYRuGGeD
Mar 28, 2005 - 6:46 PM
QUOTE(Supersprynt @ Mar 28, 2005 - 7:47 PM)
[right][snapback]263249[/snapback][/right]
im pretty sure ive read somewhere that the st205 tranny mounts work... dunno if its all three that work tho. i think i was also told that the gt tranny mounts would also work with some modifications... but thats all i know...
BBoY
Mar 28, 2005 - 11:42 PM
Well mounts are mounts and I have MR2 mounts and GT mounts. Those can be basically welded wherever. I'd like to know the specifics of where.
Green_MachToy
Mar 29, 2005 - 11:40 AM
QUOTE(Supersprynt @ Mar 28, 2005 - 3:32 PM)
[right][snapback]263127[/snapback][/right]
I had the ST205 axles and actually would not work for my swap with the MR2 Tranny. The reason is the newer axles don't have the hex screws that allow the two different types to bolt up. Because the shaft sizes are different, I don't believe you can do anything else to try and adjust the two to combine. I ended up using 185's with the MR2, but am still killing them. I have gone through two now, and after talking to a few people think it is because I also have to use the Hubs from the ST205.
Mar 29, 2005 - 12:21 PM
Yeah thats what DMC said you were doing, where are they breaking?
You got any pics of the underside of ur car (tranny mounts specifically)?
Green_MachToy
Mar 29, 2005 - 1:21 PM
The first set I actualy seized the Joint up between the inner and outer. This in turn bent the inner. $400 later I had a new set of both. This time the same joint is stretched so far, the joint is now clicking like it is ready to come apart.
I can get you pics, it will be a few days. It is at a friends house, he is trying to custom fab me the metal plate that holds the rubber seal between the hood and the bumper. I believe we usead the ST205 mounts as I had the front clip. I will take pics when I get it back.
Mar 29, 2005 - 2:13 PM
Yeah unfortunately I dont have those. I was thinking mounts must basically be the same, except there are in different locations.
sphinx
Mar 30, 2005 - 2:11 AM
i believe the axels that you're using ( st185 outer shafts) are a wee bit too short. That's why they keep going out on you. I've been using the camry outer shaft with for a while now, and have'nt had a problem. I've ran the car hard, and the axels don't pop out or break.
Super,
As for the mounts, I know the ST205 mounts work cause the are the ones I'm using and there was no modification needed. I know that you can use the GT front and rear mount and brackets. As for the driver side mounts, i know you can't use the GT mounts because the bracket is different and will not line up properly. The MR2 mounts will line up perfectly on the tranny, but not sure how it will mount up to the bracket welded on the chassis of the celica. That's why i didn't take a change and just bought the ST205 mounts. I just didn't feel like welding a mount.
I know you asked for me to post some info on mounting this tranny, but everything is pretty much straight forward. Now, if you have certain questions, by all means, just ask and i'll give you my input.
hope that helps.
Mar 30, 2005 - 7:43 AM
Where'd you find your ST205 mounts? I have a couple MR2 mounts that came with the tranny I also have the GT mounts (whcih are already on the car) so if the mounts on the cross-member already work, then I may just have the one drivers side welded, that maybe less of a headache.
sphinx
Mar 30, 2005 - 11:06 AM
I had to order my mounts through the dealer. But yeah, you just have to worry about the driver side mount. The others are ok.
Mar 30, 2005 - 11:22 AM
Excellent so it looks like what I'm going to end up doing is replacing the rubber mounts cuz mine are shot with better ones and I'll have the one welded in. The ST205 mounts will be pricey? How much you end up spending on them? But thanks I think thats good news.
Clipsetuner
Mar 30, 2005 - 12:55 PM
I am using the Solara Tranny with my 3s swap with camrey outer shafts, still tracking parts but ill be interesting.
DTE
ZoomZoom
Mar 31, 2005 - 9:17 AM
I thought your supposed to used the inner shaft of the E153 tranny and the outer shaft of the st185. how does the camry/solara outer shaft works.
If that works, then that means that you can use the whole axle from the solara/camry e153 tranny.
Please let me know.
Thanks
sphinx
Apr 1, 2005 - 12:02 AM
Ok. Here are the part #'s for the motor mounts, motor mount brackets, and shift linkage / cables from a ST205.
12361-74340.......... Insulator.......... $47.10
12371-74440.......... Insulator.......... $88.00
12372-74500.......... Insulator.......... $109.00
12311-74160.......... Bracket, EN.......... $40.00
12321-74310.......... Bracket, EN.......... $26.00
12325-74230.......... Bracket, EN.......... $53.00
33820-2B350.......... Shift Cables.......... $341.00
I ordered these through Champion Toyota and were all a special order from Japan. Those are the list prices for those items.
(713)943-7010 Direct Parts Line
QUOTE(Supersprynt @ Mar 30, 2005 - 8:22 AM)
[right][snapback]264035[/snapback][/right]
Green_MachToy
Apr 6, 2005 - 7:15 PM
What year axles from the Camry V6? I found new ones cost about $400 from a 93. I can get one from pick your part for $85 and a rebuilt for $110. I just want to make sure of the year for the fit. I have the 94 MR2 tranny and inner shaft.
QUOTE(sphinx @ Mar 30, 2005 - 7:11 AM)
Super,
hope that helps.
[right][snapback]263919[/snapback][/right]
celica3sgte
Jun 7, 2005 - 11:45 AM
This is an excellent write up. However, I thought there are people using the st185 outer shafts. I'm about to use them on my car right now, but after reading this, I want some more input. This is some direct info, on a hard to find topic. Let's keep this going. Anyone with pics of the st185 and camry outer shaft length difference should put a pic on here. Oh and what year solara or camry axles are usable?
Rjb23
Jun 7, 2005 - 12:35 PM
jgreening
Jun 7, 2005 - 12:55 PM
QUOTE(Rjb23 @ Jun 7, 2005 - 12:35 PM)
Has everyone seen this yet?
http://www.geocities.com/zegoat2000/e1531.html[right][snapback]295899[/snapback][/right]
Ah, thats celica3sgte's website...smiles.
Jun 7, 2005 - 1:09 PM
have any of you guys ever found a good place to buy rebuild axels from? i seem to be having the worst luck in the world with rebuilds. i just bought one from carquest and found out that it was the wrong size when i went to install it. this seems to happen a lot with these companies. anyone recomend a good place for rebuilds?
celica3sgte
Jun 7, 2005 - 3:52 PM
I know, I got a kit from there that was universal and wrapped around the joint and was held together w/ screws. lol. I took it back. No I haven't found a place. I'm going to test to see if the st185 outers will make the axle too short. I'm going to get the compressed and extended lengths for the GT axle, then put the mr2 inner and st185 outer together and measure. Get back with you guys in a couple days.
BBoYRuGGeD
Jun 7, 2005 - 4:48 PM
QUOTE(lagos @ Jun 7, 2005 - 6:09 PM)
[right][snapback]295920[/snapback][/right]
raxles.com check these guys out
bboy
sphinx
Jun 7, 2005 - 6:00 PM
sorry for the late response.
My axels consist of :
91 MR2 Trubo INNER shaft
91 Camry V6 OUTER shaft
bold them together, pop them in the tranny and in the hub, and you're done.
jgreening
Jun 7, 2005 - 6:01 PM
QUOTE(sphinx @ Jun 7, 2005 - 6:00 PM)
[right][snapback]296062[/snapback][/right]
The year for the inner shaft will depend on the year of your tranny.
sphinx
Jun 7, 2005 - 6:15 PM
QUOTE(jgreening @ Jun 7, 2005 - 3:01 PM)
[right][snapback]296063[/snapback][/right]
That's right. Sorry i forgot to mention that. I have a 91 tranny, hence the 91 inner shafts
And also, when purchasing the outer shafts, make sure they're from a camry with or without ABS ( depending weather or not your celica has ABS or not)
jgreening
Jun 7, 2005 - 11:09 PM
QUOTE(sphinx @ Jun 7, 2005 - 6:15 PM)
[right][snapback]296065[/snapback][/right]
One other point. When you buy the E-153, make sure you find out the year. The selector shaft and plate (and all the little parts on the selector shaft) must be from the same year alltrac as the MR2T. Actually I think the 91-92 are interchangable but the 93 is distinct.
celica3sgte
Jun 8, 2005 - 4:32 PM
This is great info, more descriptive than we had before. Advanced Auto Parts stocks the 91 camry axles. I guess both passenger and driver side axles are the same thing. Part #7409.
What kind of tranny fluid did you guys use for the mr2T tranny, and how many quarts?
Jun 8, 2005 - 4:41 PM
be carefull with axels from advance auto, they use a compay called CCT, and ive had VERY bad luck with the (wrong axels in box, some were broken, one broake after driving for 5min, etc.)
the best made axels i found were from carquest. the 1st one i bought from them (drivers side) was perfect. now i ordered the passengers side... great rebuild quality, but the input shaft is too long and wide for my car. they are working on getting me another one
jgreening
Jun 8, 2005 - 5:02 PM
QUOTE(celica3sgte @ Jun 8, 2005 - 4:32 PM)
This is great info, more descriptive than we had before. Advanced Auto Parts stocks the 91 camry axles. I guess both axles are the same thing. Part #7409.
[right][snapback]296484[/snapback][/right]
Pennzoil Synchomesh. 4 quarts. Its killer.
Jun 8, 2005 - 6:14 PM
i 2nd synchro mesh !
only problem is, im having a hard time finding it again. my local autozone had it in stock last time, but now they were out when i went to get more.
celica3sgte
Jun 9, 2005 - 3:48 AM
I found out today that the 91-92 st185 axles are identical to the 91 camry axle. I bought a pair from advanced and compared it to the st185 axles I had already bought, now i'm gonna take back the camry axles lol($271-$90 core). I took a pic of each axle side by side to show you all and i'll have that up by friday.
sphinx
Jun 9, 2005 - 1:34 PM
I'm using Redline MT-90 on my transmission. Expensive, but well worth it. I use it because I run my car real hard and I preffer having it well lubricated.
Rjb23
Jun 9, 2005 - 2:32 PM
If you use the e153 tranny do you still need the axle bracket that is not on the st?
celica3sgte
Jun 13, 2005 - 3:05 PM
Here's what I used that worked.
92 mr2 lsd tranny
92 mr2 lsd inner shafts
92 st185 outer shafts
st185 shift linkage
st185 driver's side motor mount
94-99 celica gt front motor mount
I don't have a back mount. The mount bolts to the tranny, but the insulator is almost 1 1/2" off to the side so it doens't line up.
Rjb23
Jun 13, 2005 - 3:10 PM
have you tried the st185 back mount?
celica3sgte
Jun 13, 2005 - 9:58 PM
QUOTE(Rjb23 @ Jun 13, 2005 - 1:10 PM)
[right][snapback]298486[/snapback][/right]
Yes the st185, and mr2 rear motor mount bolt to the tranny, but both interfere with the insulator on the crossmember. If the st185 or mr2 crossmember will bolt to my car then it will work.
Rjb23
Jun 13, 2005 - 11:07 PM
I think you can use the st185 cross member, when I was talking to the guy at xat about doing the e153 tranny he said something about it.
Consynx
Jun 14, 2005 - 12:28 AM
we're getting many different combos, this is a summary of what i've read so far.
here, i'll try to sum it all up, up until here:
-For Axles it's looking like Camry(91)/GT4 Outers and MR2(match yr w/ tranny) inners
-For Mounts, stock GT will work for front and rear, just need driver's mount from GT4
-For Shifter Linkage - GT4
-For Shift Cables - GT/GT4
this is just a summary.
Defgeph
Jun 14, 2005 - 1:30 AM
you have to specify which generations of gt4's
6th gen gt cables are different from st205 cables. st205 cables are different from st185 cables. st185 cables are also different from 6th gen GT's
DEF
Defgeph
Jun 14, 2005 - 1:43 AM
GT And ST205 side by side. GT is the top one
Consynx
Jun 14, 2005 - 11:47 AM
i remember this pic, which is why i am...waiting for it all the be 100% clear
celica3sgte
Jun 14, 2005 - 6:07 PM
Those cables in the top pic(which are GT cables) will not work unless the horseshoe clip is modified to be thicker. Even then, I don't think they will work. You can see the 1/4" gap between where the clip locks the cable in place and the back part. I put the gt cables in place with the e153 tranny, put the clips in that hold them in place, and there was so much slack that the cables wouldn't stay on the tranny. Is that a good explanation? I will circle the part which is different and then you can see the gap.
sphinx
Jun 15, 2005 - 6:43 PM
QUOTE(Consynx @ Jun 13, 2005 - 9:28 PM)
[right][snapback]298797[/snapback][/right]
Let me just correct this a little bit.
Axels:Inner shaft = MR2 Turbo (Match year of axel with year of tranny)
Outer shaft = 91 Camry V6 OR 91-93 All Trac
Mounts: 94-99 GT-Four mounts and brackets (front, rear, and driver side)
6th gen front mount ( be advised that with this front mount installed, we can't get the rear mount to line up, no matter if it's a all trac or mr2 mount)
Comments: I think the problem that people are having is that they are using different mounts for every side. Not all mounts are the same, and not all motor mount brackets are the same. For example, if you had all All Trac mounts but GT brackets, they will bolt up together BUT will not bold up to the crossmember becuase the bracket throws it off by an inch or half and inch. All of these things were problems i didn't want to face when i did my swap. That's why I decided to get all GT-Four mounts and brackets. I know that this setup works for a fact. If someone else has a diffrent setup, please post it. This way we can know what does work and what we can't seem to get to work.
just my 2 cents.Shift linkage and shifter cables are the same thing.
QUOTE(celica3sgte @ Jun 14, 2005 - 3:07 PM)
[right][snapback]299143[/snapback][/right]
Also, if you notice on the picture, the GT cables are a bit longer than that of a 94-99 GT-Four. I wasn't aware of the fact that the GT cables wouldn't be able to be cliped onto the MR2 tranny. I had talked to a guy at El Prototype before hand and he said that they could be used, but the problem was that once the GT cables are installed, they're so long that when shifting into 1st, 3rd, and 5th, the shifter get's too close to the consol where the sigarette lighter is at and you'll hit your hand all the time. Therefore, he advised me to use the GT-Fout cables because they're a little shorter and i wouldn't have to go through that problem. Just a thought.
Rjb23
Jun 15, 2005 - 8:38 PM
I would seriously suggest that someone call up xat racing in tampa and ask them about the mounts. I'm almost positive that they use the st185 cross member and they use custom mounts.
jgreening
Jun 15, 2005 - 10:44 PM
QUOTE(sphinx @ Jun 15, 2005 - 6:43 PM)
[right][snapback]299635[/snapback][/right]
I am using GT cables and they work without hitting my hand. I have had shifting issues though I am almost positive that they are related to the alltrac shift actuator not matching the year of my MR2T. I will report back when I have the correct actuator installed (should be next week).
