May 22, 2005 - 10:13 PM
not only is it better flowing, but also a good weight reducion mod!
Hanyo
May 22, 2005 - 10:18 PM
isnt that removing one of your cats?
May 22, 2005 - 10:20 PM
yes.... if you look at the bottom half of the stock one, youll notice that its in 2 sections. the lower secion is a cat.
Ryu3x16
May 22, 2005 - 10:29 PM
how does it sound, art? I was hoping on getting one soon but don't want my car to be so loud.. damn exhaust tickets got me all paranoid
mark_426
May 22, 2005 - 10:35 PM
did you do the header too?
ebay or elsewhere?
May 22, 2005 - 10:36 PM
i wont know for another week or so ... still have a bunch of other things i need to do on the car before i drive it again.
May 22, 2005 - 10:38 PM
i got this from berk technology. a lot of these downpipes look the same but the welds are all different. this one is quality stuff.
no i didnt get that tubular ehxaust manifold. just the downpipe
urbandork
May 22, 2005 - 10:53 PM
yeah my stock dp is hella heaviy seeing as only spent 80 bucks on it i might jsut get one of those from the get go.
May 22, 2005 - 11:03 PM
if anyone wants to buy my stock one..it is for sale.
May 24, 2005 - 9:39 PM
just wanted to warn anyone with a fmic planning to install this downpipe.
after i put the pipe in, i found out that i have a lot less room then i did before in the engine bay.
my old piping made a u turn off the turbo and would shoot straight down like this
so i had to unwrap my piping and cut up all the piping i had welded
i decided to paint the piping, came our really nice but i dont know how long it will last without chiping.
now i just need to buy silicone 90deg to make it all work again hahaa
WannabeGT4
May 24, 2005 - 9:47 PM
Why haven't you re-clocked that turbo yet?! It'll clean up that engine bay tremendously if you get that piping off of the heatshield. It can't be that hard to loosen a few bolts and twist the compressor housing. Actually I know it's not that difficult since I've got a 3S sitting in my garage now
May 24, 2005 - 9:50 PM
because from what people tell me, you can clock the turbo with no problem, but mounnting the actuator is a pain in the ass custom job.
WannabeGT4
May 24, 2005 - 10:48 PM
wastegate actuator I assume. custom plate if anything. nothing a drill, vice, band saw, and some scrap metal can't fix.
May 25, 2005 - 5:25 AM
then the problem becomes getting the piping to the side of the intercooler, and clearance between the turbo and radiator.
WannabeGT4
May 25, 2005 - 7:17 AM
QUOTE(presure2 @ May 25, 2005 - 5:25 AM)
[right][snapback]291492[/snapback][/right]
If you point the trubo outlet more towards the ground than the front that shouldn't be an issue.
chicklover345
May 29, 2005 - 9:00 PM
what is "clocking the turbo"
WannabeGT4
May 29, 2005 - 9:29 PM
QUOTE(chicklover345 @ May 29, 2005 - 9:00 PM)
[right][snapback]293118[/snapback][/right]
It's when you rotate the compressor housing so that the outlet is pointing in a different direction. In the case of the ct26/ct20b and many other small to medium sized turbos the wastgate actuator is bolted to the compressor housing so turning it is a little more complicated but honestly not as hard as people make it out to be. Actually that'll be one of the first things I do to my 3S motor besides eliminating the AFM and running a MAP based standalone EMS.
May 29, 2005 - 10:23 PM
buy a 3sgte, swap it in, clock the turbo, change over from afm to map....then you can complain about my setup
jgreening
May 29, 2005 - 10:29 PM
QUOTE(lagos @ May 29, 2005 - 10:23 PM)
[right][snapback]293149[/snapback][/right]
Great reply. Much more diplomatic than my response to the members who wanted better videos.
WannabeGT4
May 30, 2005 - 10:44 AM
Well I've already bought a 3SGTE and I've already eliminated the AFM. I've just gotta clock the turbo and drop it in. LOL! It sounds so simple.
I'm not complaining just doing my best to convince you to turn that sexy beast into an even sexier beast by simplifying that engine bay.
mark_426
May 30, 2005 - 7:46 PM
Where did you get the downpipe exactly, I can't find it...
May 30, 2005 - 8:18 PM
berktechnology.com
mark_426
May 30, 2005 - 10:10 PM
"<Exhaust>
1991-1995 USDM MR2 Turbo 3.00" Downpipe 3SGTE
Expected release date: NOW!
The Dyno graph against the leading 2.5" Downpipe. We are the three on top. Best 3 runs vs. Best 3 runs."
Do I need to call in or what, you cant add to cart... exhaust only has nissan parts.
May 30, 2005 - 10:56 PM
yeah, just call him up directly and order. if i remember correctly, i just paypaled him the money. the pipe is very good quality and has a year warrenty too.
