TruXSaMuRai
Jul 31, 2005 - 12:44 AM
i was told a hold must be drilled to fit the strut bar. where do i drill the hole?
LewFX
Jul 31, 2005 - 12:49 AM
what kind of strut bar you trying to put in?
CheesyLobster
Jul 31, 2005 - 5:03 AM
For a neon bar, mark it when you get it.
LewFX
Jul 31, 2005 - 8:07 AM
if you get a neon one, use some cardboard, cut it out to the the neon ring shape, place over bolts, press down, put neon ring on top, drill holes in cardboard to make it nice and clean, and now u got a template. place cardboard over neon ring and clamp down and drill holes, put the rings on to fit if off dremel or sand til it works, place bar, tighten bar. waa la a nice strut brace that doesnt do anything but look nice!
this should be moved to suspension
