QUOTE(jayd265 @ Aug 7, 2005 - 3:21 AM)
ok i went and bought a thermostat and we changed it out. and so far its working fine. we will just have to wait and see til tomorrow when im driving it. lets hope for the best!
[right][snapback]321361[/snapback][/right]
If the thermostat doesn't fix it which it probably will. It could be that your fan is not working, or that your radiator is bad. I'm not sure if this happens with toyotas but jeep radiators(peice of crap chryslers) the little fins in the radiator rust and break away from the tubes, causing it to overheat because those little fins are what helps to dissapate heat.
But the thermostat is more than likely the cause.
