QUOTE(playr158 @ Aug 9, 2005 - 8:15 AM)
illyont your view is a little off..
If your factory cat is broken, adding the Greddy system will still make you fail emission tests.
if your factory cat is broken and you add a greddy system you will fail because of
your broken cat NOT the greddy system
greddy = cat back meaning from after your stock cat converter back
[right][snapback]322217[/snapback][/right]
Like I said..
I didn't say you fail because of the Greddy system.
me: "If your factory cat is broken, adding the Greddt system _will still_ make you fail emission tests".
That means of course, you will fail without the Greddy, and with the Greddy.
I also said this:
"Greddy is street legal because it uses the factory cat (as people have already said)."
So I think my post was clear.
