SoundSlut_dotcom
Aug 8, 2005 - 4:36 PM
I got the strut kit.. and the hoses POP right in,, no tightening or anything, i called the company and called them like 'quick connects' or some ****.. these things look like with some air there gunna rip right off... did u have to just pop yours in with out tightening them????
thanx. SS.izzle
Digndoug
Aug 8, 2005 - 8:17 PM
My brother has air struts and they pop right in, but there are connectors i think that go inside or somthign so when pressure is applied theres a back force to hold it in. But he is always having problems with lines breaking leaking, or valves stop working.. but man are they fun.
kristinw85
Aug 8, 2005 - 8:35 PM
WHY can't anyone spell my name?!?!?!?!?! lol
Well, I wish I had the answer for that, but...... I paid a place to put my air ride on so I don't know....sorry
95gtschick
Aug 8, 2005 - 10:19 PM
lol hey i'm with you on that.. my name is krysten as well.. but everyone wants to spell it your way
SoundSlut_dotcom
Aug 9, 2005 - 12:11 PM
my sisters name is spelled kristin... ts rare so i figured urs was the usuak kristen.. lol
SoundSlut_dotcom
Aug 9, 2005 - 12:12 PM
ne probs w ur air ride kris??
kristinw85
Aug 9, 2005 - 6:08 PM
nope none at all
mark_426
Aug 9, 2005 - 9:08 PM
well, i dont know about your specific application, but I have used push connect "macro" air fittings. They seal when they're pressurized.. they're like chinese finger traps
with the ones i have used, if they look like this, theyre good to about 1000psi of air:
Phat_99CeliGT
Aug 9, 2005 - 9:51 PM
u put the hose in and slightly pull on it. it is suppose to lock in the connector.
mine r like the pic, but i have plastic ones. im not pushing mass psi to upgrade to the brass ones.
SoundSlut_dotcom
Aug 10, 2005 - 12:07 AM
my front driver side keeps blowing out.. and i checked for leaks ,, i got mad leaks... they make thsee kits like ****
SoundSlut_dotcom
Aug 10, 2005 - 12:08 AM
thanks for the input guys.. my damn compressor dont shut off either.. it was ruinnign for over 15 mins, i have to shut the car..
Phat_99CeliGT
Aug 10, 2005 - 12:37 AM
when the hose pops out, u can't just pop it back in.
look at the end of the hose that keeps popping out. if it is gouged(sp?) u need to take a razor(NOT CUTTERS)and cut the bad off of the hose.
what psi pressure switch do u have?
what size compressor?
how big of a tank?
i have a 5gal. tank with 2 thomas 377 1/4hp compressors. takes about 5 minutes to fill my tank.
SoundSlut_dotcom
Aug 11, 2005 - 1:07 AM
ok... i changed all the fittings... becuz the fittings they gave me blew goat cock.. i checked for leaks... i had about 40.. i changed all the connectors too.. the other hoeses with the old fittings kept blowing rite out....
as far as the compressor problem... my switch was 175psi... it holds 150psi... i just bought one for 135psi... for the cuttoff
SoundSlut_dotcom
Aug 11, 2005 - 3:34 PM
1 more question maybe you would know phat... you have a 19" rim on bags, what size tire and does it rub / how much clearance do u have, I made my car alot wider.. and i was going to go with a wider size 19" rim... do u do any modifications?? thanks alot
Phat_99CeliGT
Aug 11, 2005 - 5:08 PM
i have 18's
the widest i cacn get on the rear is 215-35-18. im not sure of the offset, but u cann't even get your pinky between the tire and the wheelwell lip.
u can try and email bkohler81.
she has 19s with bags.
Jaws4God
Nov 22, 2005 - 6:29 PM
Do you guys have any problems with the fronts and turning? The steering is very jerky and doesn't feel right at all...
