New Apexi Boost controller, this thing is scary. Soooo complicated to set up.
and a decat pipe
Turbo spools up real quick now, exhaust note has increased in depth and Db level too. Car goes like **** off a stick now, cant wait for the next mod, whatever that turns out to be.
Fitting the decat pipe was a right pain, took me two days to do correctly, with one or two other little jobs aswell, am now missing most of the skin off of my knuckles and have gained several cuts and bruises totally recomend this mod to anyone, not only does the turbo spool up quicker as I mentioned, it also saved alot of weight, the old cast cat pipe weighed in at a portly 16Kg (34Lbs) while the new SS decat pipe weighs only 2.1Kg (4.5Lbs). Jobs a good un.
Even more Smiles per hour now
