I'd sat that if the ST202/4 has Superstrut, then it is going to fit. I wouldn't be so sure if it is the macpherson type though.
Fitting isn't as straighforward as you would think. 3 out of 4 bolts are easypeasy - especially with air tools to hand
Bolt number 4, by the sump is an issue. Needed to undo the cambelt end engine mount so the motor could be 'lifted' up that end to allow clearance for the suspension bolt to be removed and the replacement one to be inserted
Otherwise it would have been a 5 minute job
It may be different for the ST202/4 - depends on the sump layout on teh motors as I
think the Gen III 3S-GTE is different to the n/a ones.
Gary
