DmVinny
Nov 30, 2005 - 10:28 PM
Hey guys, I'm having a problem, I am experiencing surging when I drive, it seems like it's bogging, than it will try to pick up than bog down than after about 3 or 4 surges it's fine till next gear... I've changed my air filter, oil filter, distributor cap, and ignition coil today and it still seems to be happening... any suggestions?
jayi12-15psi
Nov 30, 2005 - 10:34 PM
do you have cel light on? any vaccuum hoses broken?
DmVinny
Nov 30, 2005 - 10:35 PM
If you mean my engine light, no it's not... i check the vacuum hoses quickly but didnt notice any broken ones... I also changed out my pcv valve.
Dunners
Dec 1, 2005 - 2:12 AM
I reckon it might be you're spark plugs, the same thing was happening to me last year and after changing the plugs it was fine. In the mean time i found that if you hold down the accelerater to 3500 rpm for about 1 second before you take of it makes it not so bad. Hope it helps.
TrD3sgte94
Dec 10, 2005 - 7:39 PM
same thing happened to mine last year and all i did was replace the sparkplug wires but you should definetaly check your plugs and make sure they are gapped while you have them out.
-wess-
BBoYRuGGeD
Dec 10, 2005 - 8:10 PM
by surging u mean hesitate?
bboy
