Ok. I have been stress out the last couple of weeks at work.
He is right. I am very sorry.
(Unconsciously, I knew the statement below would work when I told you so. I had always knew and did not think twice when I lose my VVT-i upgrading to bigger cams)
You can use the 3SGTE Cams since the 3SGE gen 4 head is the same in the cam profile as the 3 gen 3SGTE.
Even it you lose the vvt-i, it is ok since you will be running big cams to over come that effect.
I will contact toda racing on your behalf and post the email here. Is that alright?
You see, at the end of the day, you are modding to the 3SGTE specs.
There is no strenght differents in the blocks of the 3rd gen 3SGTE and the 4 Gen 3SGE.
http://www.toysport.com/ENGINE%20EVOLUTION...0THE%203SGE.htmhttp://www.toysport.com/3sgt_tech_notes.htmDid you check out that site.
In the usa, there are really specialise there. Toda racing is a Japanese company.
There make racing parts for all the well know cars.
Alot of 3SGTE builds ups come from the 3SGE which is contrary to manu USAer believes.
It is may be easier to get the a 3SGTE block, but it can be started from the 3SGE block, install some oil coilers in the head (maybe present in the latest gen 3SGE, 11.5:1) since the 4AGE 20v have them.)
http://www.todaracing.comIf you need help with the english, you have all of us here.
I have msn and AIM.
Again, I wll try and see what toda can do for you.
Look here!
A 3sge is a 3sge.
Available for: 4AG, 4AG (5 valve), 3SG, 7MG
TODA Racing offers a complete valve train package for the 4AG, 3SG, and 7MG. These kits are recommend when using high lift, long duration camshafts. They will prevent engine damage and power loss due to valve float.
Engine Price Comment
4AG $880 Complete Kit
4AG $220 AE101 (5 valve engine) Valve springs only
4AG $220 AE111 (5 valve engine) Valve springs only
4AG $120 Valve Springs Only
3SG $900 Complete Kit
Available for: 4AG, 3SG, 3SGT, 1ZZ, 2ZZ
(4AG Flywheel shown)
TODA Racing lightweight flywheels increase throttle response and aide in overall vehicle performance. These are not modified stock flywheels, but brand new units produced from 100% chromoly steel. In addition to these flywheels, TODA Racing also offers high performance clutch packages which include a TODA flywheel, pressure plate, and disk. Please contact us for pricing on clutch kits.
Engine Weight Price Comment
AE86 4AG ~ 4/1987 3.7 kg $450 Fits Corolla and AW11 MR2
AE92 4AG ~ 4/1989 3.7 kg $450
AE92 4AG 5/1989 ~ Up 4.4 kg $450
AE101 4AG 4.4 kg $450
SW20 3SG 4.5 kg $450
SW20T 3SGT 4.5 kg $450
Toyota 3SGT Camshaft Specifications
Price :$370 (For cams up 9.8mm lift); $490 (for cams with more than 9.9mm lift)
Part # Duration Lift (mm)
3SG-SW001 256 8.5
3SG-SW002 256 9.0
3SG-SW011 264 8.5
3SG-SW012 264 9.0
3SG-SW013 264 10.3
3SG-SW021 272 8.5
3SG-SW022 272 9.0
3SG-SW023 272 10.3
3SG-SW031 280 10.3
3SG-SW041 288 8.5
3SG-SW042 288 9.0
3SG-SW043 288 10.0
3SG-SW044 288 10.5
3SG-SW051 304 8.5
3SG-SW052 304 9.0
3SG-SW053 304 10.5
3SG-SW061 310 10.5
3SG-SW071 320 10.8
3SGTE 98-99 86.0 86.0 1998 9.0 260 6000 CALDINA ST215
3SGTE III 96-97 86.0 86.0 1998 8.5 255 6000 CELICA GT4 C. ALLTRAC ST205
3SGTE II 98-99 86.0 86.0 1998 8.5 245 6000 MR2 MR2 SW20
3SGTE I 92-93 86.0 86.0 1998 8.8 225 6000 MR2 MR2 SW21
3SGE IV 99-00 86.0 86.0 1998 11.0 210 7600 ALTEZZA DVVTi
3SGE IV 98-99 86.0 86.0 1998 11.0 200 7000 CEL. SSIII ST202
3SGE IV 98-99 86.0 86.0 1998 11.0 180 6600 RAV4 SXA11
3SGE III 96-97 86.0 86.0 1998 10.3 170 6600 CARINA
3SGE II 92-93 86.0 86.0 1998 10.0 165 6800 CELICA
3SGE I 86-89 86.0 86.0 1998 10.0 145 6500 CELICA
Engine Type Valv/Cyl Year Disp. BHP Torque Bore Stroke CR stock boost+other remarks
/angle [*=JIS] [lb ft] [mm or inches]
3S-GE DOHC 4/50 95-98 1998 180@7000 142@4800 86 86
3S-GE DOHC+VVT-i 98- 1998 190@7000 152@6000 86 86
3S-GE DOHC+DualVVT-i 99 1998 200@7000 159@4800 86 86 11.5:1 JP Altezza (Auto5spd)
3S-GE DOHC+DualVVT-i 99 1998 210@7600 159@6400 86 86 11.5:1 JP Altezza (6spd)
3S-GTE DOHC 4/50 95-98 1998 255@6000 225@4000 86 86 (Celica GT-4 Japan)
3S-GTE DOHC 4/50 98 1998 260@6000 239@4400 86 86 (Caldina GT-T Japan
