Nemises
Mar 15, 2006 - 4:30 PM
Hey guys I need your help. As some of you know I bought a 94 celi. However one of my axels keeps popping out leaking all my diff fluid out. Heres the thing the shop just called me and apparently my tranny was replaced and the new parts for the 94 arent fitting. So heres my question what are the differences in celi trannys over the years. My celi is a five speed. Where their any tranny changes from 94-99? I was thinking maybe it was replaced with a newer tranny that might be a little different? Any thoughts? The shop really doesnt know what to do at this point?
Kwanza26
Mar 15, 2006 - 8:45 PM
There were no tranny changes, they're all the same.
If your shop can't figure that... well... how lame.
My hypothesis is simple you see,
they got the wrong axle, it's shorter than it should be.
hence the popping and leaking and squeaking, and sneeze.
Another possibility, I surmise you should check,
the axle's snap rings, may have lost their connect.
this can cause the shaft to shake and foil,
under load and going will loose your trans oil.
Check those things and I hope you won't spoil.
burneeed
Mar 15, 2006 - 8:59 PM
well as many people can say the same. I got the wrong axles from advanced about maybe 4-5x..... Until they finally gave me the right axles. I cant explain ths one its just really goofy. Your best bet is to just go oem from toyota.
