81726st
Jun 4, 2003 - 2:35 PM
I need help on flushing and replacing my transmission fluid and filter. I was told that there are two bolts to loosen, one is drain bolt and one is refill(???) bolt. I was wondering if anyone can tell me if thats right or basically a how-to on this, or even any website that has this info. any opinions, help or advice is greatly appreciated!!! thanks in advance
kyle314
Jun 4, 2003 - 3:02 PM
auto or manual
81726st
Jun 4, 2003 - 3:10 PM
95 celica st auto
exxtractor
Jun 4, 2003 - 4:20 PM
I know this is more expensive, but it might be easier to just have the dealer do it, the dealer I go for auto trans fluid replacement is cheaper than say jiffy lube, etc.
1858
Jun 4, 2003 - 8:43 PM
QUOTE (81726st @ Jun 4, 2003 - 11:49 AM) |
I need help on flushing and replacing my transmission fluid and filter. I was told that there are two bolts to loosen, one is drain bolt and one is refill(???) bolt. I was wondering if anyone can tell me if thats right or basically a how-to on this, or even any website that has this info. any opinions, help or advice is greatly appreciated!!! thanks in advance  |
That's for manual tranny only.....and if anyone is gonna change the manual tranny fluid, make sure you can undo the filler bolt before you drain it, or you'll be screwed with the oil out of the tranny and can't fill it back up.
For auto tranny, there's a drain bolt on the pan, at the bottom of the tranny. To get to the filter, you'll need to take the pan off as well. To refill it, you'd pour the oil down the dip stick tube. You could also stick a tube down the dip stick tube and suck the oil out too. But either way, you wouldn't get all the oil out. To do a really good flush n refill, a shop would use a machine to do that.
Take a look at the current issue of Popular Mechanics; there's a good how-to article on changing auto tranny fluid that I read it at someone's house. Probably the June issue.
macavely
Jun 4, 2003 - 11:13 PM
ok and auto transmission is a real bitch to change the fluid in....you need a machine to drian all the fluid out of an auto trans..so i would tell you just take it shop and let them do it...
6JenCelica
Jun 4, 2003 - 11:19 PM
yea take it to toyota... its worth it not to screw anything up
good call Macavely
kyle314
Jun 4, 2003 - 11:55 PM
yeah bring to us it takes about an hour and all the fluid get removed. its well worth the cost and adds life to ur trans.
81726st
Jun 5, 2003 - 9:30 AM
thankx for all your response, shop it is then...
