QUOTE(bigal004321 @ Apr 22, 2006 - 12:09 PM) [snapback]424843[/snapback]
See it does have ABS relays,,, so i am unsure of whether the axles woudl also be ABS..
Thanks for the help!
Bigal
Look in the engine bay, man... come on! There will be an ABS unit with a bunch of brake lines to and from it. (if its an MR2, the ABS unit should be in the front trunk somewhere, I think)
You can't tell anything from any of the pictures you posted. The part of the axle with the 'toothed' section slides inside the hub and is hidden. An extra sensor bolts on the hub (two wires go to it) that you can also look for, but it wasn't clear from the pictures whether that sensor was there or not. The fuse box cover has the same printing on it whether there is ABS or not - you need to match it to an actual picture of what is actually in the fuse box.
-Charlie
