Ok, well i recently ordered a 9 lb. flywheel from Competition Clutch, best service ever, great price, well i got the flywheel and i matched everything up, teeth for started, pressure plate pins, everything was perfect. Except for the mounting holes to the crankshaft. The flywheel i got had 8 holes, while my crank only has 6 holes. Now obviously that will not work. The engine is a 94 7-afe. I was wondering first of all if anyone has ever found a performance flywheel that will fit and bolt up to this specific engine? and second, what are the differences between the 94 7-afe and the 95-98 engines? except for the obviouse power differences. is the crankshaft on the newer engine an 8 bolt? sorry if this has been posted before, but i have not found any info when i searched.
Thanks for your help.
Matt
