I was having trouble with my clutch a few months back... every now and then it wouldnt shift properly and had to be forced. I figured the clutch needed to be replaced, it has 110k+ miles on it and just seemed to make sense. In order to avoid any trouble i figured i would take it to Toyota and pay the extra money to have it done right. They replaced my master and slave 900 and when i get it back it wont even shift... No grinding... it just wont got into different gears. Its fickle, cause sometimes if i work through the gears before i turn it on once i get going it will be ok and then later give out. I take it back they say i need a new Clutch Cable (still not sure what that is), and that i have a couple oil leaks that caused the cable to deteriorate. Ok i think i needed to fix the leak anyway so 1300 dollars later the leak is fixed and cable replaced. They said during the test drive that my clutch was slipping but when i went with the guy to take it around the block i didnt notice anything. So i take it home, only to have a new problem. After i leave first and stop again it wont come out of neutral, So at every stop sign i have to turn off the engine and start back up in first gear. Then it wont down shift of shift properly either. The shifter just moves back in forth in the neutral zone and wont go into gear. Just wanted to know if you guys think this is kinda fishy (or had any ideas as to what the problem is)... If replacing the clutch will fix this then i'll gladly lay down the 900 they're saying it will take but I'm worried that another problem will "pop up" and my car will never be fixed.
Please Help!!!
