Full Version: 3S-GTE Stroker Kit
Inferno
I thought about posting it in the parts directory, but I wasn't sure if I should. Anyhow, I found it on the JUN site. Maybe you guys with a 3S-GTE might like it. Here it is. Of course, you'll have to scroll down to the 3S-GTE, as their are many other famous Japanese engines on there.
aaronc222
Someone posted about a shop in Chicago a while back that specializes in 3SGTE upgrades. They had a 2.2 stroker kit there as well, I'll post the site when I'm back on my PC.
mywhite94celicagt
i wonder what kind of power you would get with the stroker kit???? and i wonder the price too???
Junior
You would get a little more low end torque, and probably lose a little in the upper range HP. The best reason to get this stroker kit is so you can increase your boost (By a lot) and/or throw in NOS.
97sccelica
QUOTE (Junior @ Jun 10, 2003 - 8:53 PM)
not just that but the extra displacement means more gases go out of the exhaust ports and through the turbo which makes for less lag, or tolerable lag on a much larger turbo.
and mod for mod, 2.2l will make more hp than 2.0l
0Re0
It cost around $5,141.12 for that kit....without shipping! The only way to get it is if you can order by FAX and
purchase our products directly from JUN in Japan. Contact Toshiyuki Takahashi at takahashi@junauto.co.jp PHONE +81-3-3920-4165 / FAX +81-3-3920-4176 Just ordered me that JUN Camshaft kit Stage2 w/ the cams for my 3SGTE from him for $1,300.00 shipped.
Or you can get their products from tuning shop or distributor inthe USA area. However,they do not have any authorized dealers in the USA area. I was informed that JUN USA got closed down. Check with http://www.takakaira.com/ and http://www.Japanparts.com but the price will be higher. Goodluck! biggrin.gif
0Re0
QUOTE (aaronc222 @ Jun 10, 2003 - 4:01 PM)
From what I've heard....You can use a 5S-FE 2.2L Crankshaft on a JDM 3S-GTE motor. All you need is the piston kit and connecting rods and bolt which will cost you around 3Gz. $ave!
west_minist
Toda racing have one.
These kits are for serious import tuners.
Not for the light hearted
aaronc222
Here it is: CJ Motorsports
They do all sorts of stuff to 3SGTEs.
west_minist
www.extremeboost.com in canada seems to be very good to.
Inferno
