OK. I took some overly detailed pictures for you
here goes...
Taking the Cigarette Lighter OUTPull the shifter surround out and unclip the shift boot. then you see this
unplug the cigarette lighter
unplug the light by twisting it then pulling it out
then you are left with this
the black piece comes off fairly easily
the two pieces to it will probably come apart, don't worry about it
then you should have this
just push the lighter assembly out from the back
and you now have this
now just pop out the other plastic piece pushing out from the back again
and its out. congrats
now the fun part
Putting the Cigarette Lighter Back INtake the piece in the last pic above and match the tab to the indentation in the shifter surround and push it in
on the cigarette lighter itself there are two tabs, a smaller one and a bigger one. they match up to the grooves in the plastic piece you just put in
line them up and snap it right in
again you are left with this. everything should line up perfectly on this side now (more little tabs and grooves)
put the two black pieces back together and slide them on. they might not snap in and stay in place, thats fine, when you put the LED back in it will hold it
then just plug everything back in the way you took it off
and Congratulations you are now back where you started
