QUOTE(WannabeGT4 @ Jul 31, 2006 - 10:28 AM) [snapback]463538[/snapback]
Hmmm.....if you had done the research, I would have thought you would have seen the threads that Justin posted. Maybe you just need to research a bit more. Good luck with your project.
I personally like the second thread - that part about his testicles has me rolling everytime I read it!
No offense Justin, some of us just have the curse!
On to the technical bit, Justin, if you utilize the 5sfe ECU to run only the tranny, won't you get all kinds of errors because the ECU is not seeing the engine and its inputs?
