Full Version: Toyota Land Cruiser Help! Urgent! Rotor!
HyperDeathKill
Hey guys,
I know this doesn't really really belong here, but I'm in desperate need of help. I'm trying to replace the brake rotor on my friends mom's 96 Land Cruiser, and I seem to have removed everything holding it on - wheel, studs, lock retainer, greese cap.
Here's a picture of where we are.
What do I do now? The thing is just...on there!
HELP! NEED TO GET THIS DONE!
GeEkBoY
hope I am not too late to help. There should be a threaded hole in the rotor. Find a bolt that is the same thread as the hole. Screw it in and it should force the rotor off. If that does not work, try a hammer since you are replacing the rotor. The rotors tend to rust to the hubs over time.
good luck
hi_rider
Check the new ones you've got.
See if the brake disc comes with the wheel bearing...if so, you must take off the bearing.
If not, well, good luck ! Try to figure it out with the new one shape and all
HyperDeathKill
Thanks geekboy. I'm good now.
