nate95
Jan 10, 2007 - 4:31 PM
anybody know what to do to fix a leaking radiator?
Jan 10, 2007 - 4:43 PM
get a new one. im not being sarcastic. just about no quicky repair will hold pressure for very long on a radiator. you can get a new one for relatively cheap and installation is easy as pie.
SL44
Jan 10, 2007 - 11:32 PM
Mine leaked so I did the same as I have done for a couple other cars, get a new one from 1800RADIATORS (now they are something like radiators.com). I originally did this like three years ago. The good thing about them is they have a lifetime warranty. I am now on my 7th radiator from them; no exaggeration. I still have problems with the engine temperature when it is over 90°F outside and going up a hill; forget about running the AC. Typically, the temp gauge does not budge from a little under ½ way between the full scale. On those hot days, I constantly have to keep an eye on the gauge and back off on the speed when the gauge approaches ¾ full scale.
I have used the 1800RADIATOR replacements in my old '77 Celica GT and '95 Ford T'bird and had no problems. They cannot explain why their product does not seem to work too well on my '94 Celica GT.
I also replaced my cooling fan #2 motor, this helped a bit as the old one was able to be stopped easily with my hand, wrapped with a towel.
I recently flushed the cooling system, then replaced the water pump and thermostat when I did the timing belt; I'll have to wait until the weather gets hotter to see if these make a difference. I'm dreading the onset of summer and those 100°+ days that accompany it.
I can't be the only one this cooling problem has happened to; anyone have any suggetions?
Jan 10, 2007 - 11:45 PM
switch upto a larger radiator. if you have a manual, a stock radiator from an automatic may have a larger cooling capacity. if not then an all aluminum radiator which is thicker should be able to dissipate the heat. i hear koyo radiators are good.
SL44
Jan 11, 2007 - 3:37 AM
Bitter, thanks for the suggestions. I just hate throwing more and more $ at it, but I'll have to do something; I'm tired of sweating, literally and metaphorically.
6gsillyca
Jan 11, 2007 - 3:46 AM
use an egg. a raw one. put it into your filler cap.
Jan 11, 2007 - 5:55 PM
QUOTE(6gsillyca @ Jan 11, 2007 - 3:46 AM) [snapback]516974[/snapback]
you trying to make a toxic poached egg slushy?
Jan 11, 2007 - 6:36 PM
that only works on TV macgyver
also, I have a 95 ST radiator M/T no leaks if you want it, $50 shipped
nate95
Jan 11, 2007 - 6:54 PM
you really have one? and sell it for $50? how hard is it to pull out the stock one and put another one in? my fans are already off.
Jan 11, 2007 - 7:07 PM
if the fans are off then it's real easy. Disconnect the 2 hoses (upper and lower) then 2 bolts on top and slide it up and out. If the fans are out it's a 5-10 min job. When you put it back in, just put the fans on the radiator first, then drop it in place
PM me if you want it
snapshotgt
Jan 11, 2007 - 11:18 PM
I've got a GT radiator for sale as well if anyone is interested. It is is real good condition. PM me if anyone is interested.
Thanks-
6gsillyca
Jan 12, 2007 - 2:39 AM
QUOTE(Bitter @ Jan 11, 2007 - 3:55 PM) [snapback]517140[/snapback]
No. if you are driving down the freeway and you suddenly spring a hole, putting an egg into your rad will help seal it. The egg will cook, and the pressure will temporarily "plug" the hole. It works better than leaving a coolant trail.
king_wsk
Jan 12, 2007 - 4:47 AM
When I bought my car, the lady was asking $4,500, but when I popped the hood and saw a the steaming radiator (squirting fluid up too), I made the offer for $3,500 and she bit. So, I changed the radiator and then 3 weeks go buy and it starts leaking again. Thankfully the place I used had a lifetime warranty on it and I got another one. I haven't had a cooling problem since... well until I found out that my car burns oil.
Make sure you have plenty of oil. Our 94 GT hatches like oil... alot. Well all 5sfe engines over 75k miles do.
nate95
Jan 12, 2007 - 9:10 AM
QUOTE(Batman722 @ Jan 11, 2007 - 7:07 PM) [snapback]517163[/snapback]
hey, thank you very much for this offer, iam going out of town today and will be back saturday evening, i will let you know then if i want the radiator, i more than likely will buy! thanks!
