mneal2_92788
Jan 18, 2007 - 1:39 PM
i was told my car is leaking transaxle fluid...any ways to fix this? inexpensivly? also my head gaskets, i need new gaskets but i dont know how to get the heads to come off? any help at all?
Jan 18, 2007 - 2:49 PM
you mean your valve cover gasket, not your head gasket, right?
valve cover is very easy. all you do is remove your spark plug wires and unscrew the 4 30m nuts that hold the cover down.
if your leaking tranny fluid then chances are its from your axle seals. not a hard job at all, but then again it all depends on your skill level with cars.
