QUOTE(easternpiro1 @ Feb 8, 2007 - 4:20 AM) [snapback]524929[/snapback]
tune up was included?
Actually you're right, the tunup was not done on yours. Of course you have the MUCH newer 4th gen engine, but something I forgot to add to that list is the custom a/c and p/s lines and such.
QUOTE(illneversellmycelli @ Feb 8, 2007 - 4:23 AM) [snapback]524931[/snapback]
and the most important question
i need to read up again
horse of 3rd gen 3s 255, 4th gen 260, then you boost in stuff yadda yadda
whats the horse of the v6 stock say a ......3mz
The MZ engines make from 190hp (early 1MZ) to what... 210, 220 for the 3MZ? And a little more torque than hp in each case.
QUOTE(snapshotgt @ Feb 8, 2007 - 4:48 AM) [snapback]524933[/snapback]
Okay, I feel as though I’m called to post in this thread before too many people start jumping on this idea because it is "cheaper than a 3sgte", and the general info being provided about this swap.
My car is currently undergoing a V6 swap. I'm not personally swapping it, but I KNOW nevertheless what it takes financially and physically to do a proper V6 swap into our 6th gens.
To start, here is a quick, small quote from the guy who is swapping my engine. He is 33, and has been working on Toyota engines for many years, his experience needs to mean a lot to anyone serious about this. He is personally working on this swap, and knows what is takes. Period.
forget about using 5sfe tranny .. mr2 guys breaking these trannies and it is half ass anyway.. just get a proper solara tranny with rear st205 mount .. all st205 if possible .. use poly mounts as well to keep the motor solid b/c torque will make engine move and hit rad .. use st205 shifter cables as well ..
Many of you need to consider the amount of money you end up investing into this swap -- don't you want it to be done correctly the first time? Did V6 Solara's come from the factory with 5s trannies? No. Yes, it costs more up front, but in the long run WILL save you money. You can ask many MR2 V6 swappers, and they will tell you the same.
I'm not going into specific prices of parts, running totals etc, but I can tell you Doc's quote is NOT accurate for a proper V6 setup. Doc, this is nothing against you, just posting a fair and balanced representation of this swap for everyone here. I don’t like to see people being mislead about what a proper V6 swap requires.
I'm sure the person working on my car, and HAVING FIRST HAND EXPERIENCE with this swap will chime in on this subject.
BS. Don't be angry because your swap is taking twice as long and costing twice as much because you cut me out of the deal, after all the TIME and WORK that I spent guiding you through how we would do it and finding out all the info for you (I have like 1000 emails in my inbox from you), not to mention the many phone calls I had to make to the guy you bought your engine from so that you ACTUALLY GOT IT.
For one, you're going with a FULL REBUILT 3MZ engine which had like 10k miles on it or whatever. That added a lot to the cost of your swap. Then, you were convinced that you HAVE TO use an E153 tranny, which is NOT TRUE. Let's not start this myth again. Consider the facts: There are dozens of 3SGTE swaps on this forum that are running 225 to 250 flywheel hp 3SGTEs. I've never seen a confirmed case where a near-stock 3SGTE damaged an S54 tranny. Then, consider the 4th gen 3SGTE that I swapped into easternpiro's car. He is running 260hp AT THE WHEELS, with a GT tranny, NO PROBLEMS. Fastbird, we're running his 2nd gen 3SGTE, modified and dyno-tuned to 250 WHEEL HP and 250 ft/lbs of tq, NO PROBLEMS. It goes on and on.
The most powerful MZ-series V6 makes what 220hp, 240 ft/lbs at the crank? That's about 190hp and 205ft/lbs at the wheels? Which is SEVENTY HORSEPOWER LESS and at least FOURTY-FIVE ft/lbs LESS than easternpiro's 3SGTE. Which the GT tranny handles NO PROBLEM. I'm talking about first-hand experience here as well. There is no doubt at all, that a GT tranny will have NO problem with even a mildly modified V6.
Then, since you're using an E153, you needed to order ST205 mounts from Japan, get some customized axles made, just to get the engine bolted in! Add the poly inserts (good idea, but not required), ST205 cables, etc....
Now listen, I'm NOT saying that you're not going to have a nice setup when it's done. Your setup is IDEAL. It's also the MOST EXPENSIVE way to do it. Most people aren't going to want to spend that much, nor are they going to have to. Let's consider how much a reliable, but less expensive 1MZ swap would be. Let's look at it from the perspective of a GT owner.
Before you go any further, keep in mind that these are all high-end prices. Don't fall out of your chair when you see how quickly quality parts add up! By reading further you hearby release 6gc.net, Dr Tweak, and their affiliates of any liability, should you fall out of your chair and land on your cat, or anything like that! Used, low mileage (60k or less) 1MZFE engine set (OBD1, return-style fuel system) $850 HIGH END. You can score these engines CHEAP if you shop around and pull it yourself.
Flywheel for 1MZFE $250 (HIGH END)
Performance clutch kit $350 (HIGH END)
Custom passenger-side mount $150
Labor, at my shop SCC in Savannah, GA, for a FULL swap, $2000 (HIGH END)
Custom a/c and p/s lines $250 max
Custom y-pipe and FULL, CUSTOM-MADE MANDREL-BENT STAINLESS STEEL 2.5" exhaust, $950
Custom cold air intake (not required) $200
Misc items (fluids, fuel pump, filters, etc... let's add $900 to it here just to be safe $900
Right now we're up to $5900 MAX for V6 swap, including a bunch of stuff we don't HAVE TO have (like the stainless exhaust, CAI, etc). If you have an ST, you basically need to add the GT tranny, axles, and mounts, let's say another $1000 to be safe so $6900 MAX. If you have an auto, you need to add in the manual conversion parts and a little more labor, say another $600.
So, on the VERY top end of the scale here, we're right in the same range as a 3SGTE. If one really took their time shopping for parts and didn't go overboard with then that weren't really needed, then a swap could probably be done for around $4000 on the low end, including labor.
Let's do a 3SGTE swap real quick just for a good comparison (most of this is taken from my "3SGTE Swap Checklist" thread, but I'm updating some things)
Good 2nd gen 3SGTE Engine set $1500 ($1900 for a 3rd gen)
Shipping $350
Front-mount intercooler, piping, clamps, couplers $600 to $1000 depending on intercooler quality
Aussie downpipe $350 shipped
Misc (Fuel pump, filters, fluids, etc) $600
Labor for swap, wiring, AND custom-install of front-mount and piping $1800
Full stainless-steel, mandrel-bent custom-built 3" exhaust system $950
Total basic 3SGTE swap into a GT $6500 to $7300
For an ST, add the GT tranny, axles, mounts, custom a/c and p/s lines, for an additional $1250 max, so total is $7750 to $8550. For an automatic, add an additional $600 for the manual conversion and parts.
Now again here folks, just like with the V6 swap we itemized, we're going HIGH end. You don't need to use the Aussie downpipe, many people opt for the cheapo-ebay one. And again, a full stainless mandrel-bent exhaust isn't required. The point is:
MOST ENGINE SWAPS WILL COST LESS THAN WHAT IS SHOWN HEREBut we want to make sure that we're comparing apples to apples. So comparing right across the board, V6 to 3SGTE, here's what we've got:
3SGTE basic swap: $6500
V6 basic swap: $5900 (difference $600)
3SGTE into ST swap: $7750
V6 into ST swap: $6900 (difference $850)
In each case, it's a good idea to do a full timing belt/reseal/tuneup of the engine right before it goes in, which typically runs about $850 for parts AND labor.
So, not really a big difference, but for the coolness of the V6 engine, plus rock-solid reliability and ease of maintenance, going the V6 route is a great idea and you STILL save a few bucks!
-Dr Tweak
