95STHATCH
Jul 21, 2003 - 11:07 PM
I noticed today that my rpms jump up and down when I give it gas around the 2500-3000 rpm range. My throttle cable needs to be replaced,could that be the problem???? I just need some help.
Jul 22, 2003 - 12:35 AM
why does ur throttle cable need to be replaced?
ur RPMs wouldnt jump, they'd probably just stick.
95STHATCH
Jul 22, 2003 - 10:31 PM
The throttle cable sticks at low rpms and thats why I need to replace it but,when I give it gas in lets say 5th gear while its between the 2500-3000 rpm range it will jump uplike i want it too but then a split second later it will drop back down then jump up and down again.
t96f
Jul 30, 2003 - 9:12 PM
Sounds like slipping clutch!!
95STHATCH
Jul 30, 2003 - 9:42 PM
Would it be slipping in 5th and not be slipping in 1st? It might be a stupid question because i've only been driving a 5 speed fpr about a month.
t96f
Jul 31, 2003 - 12:25 AM
you didn't say was only in 5th and not first LOL
Stealths95GT
Aug 4, 2003 - 12:08 AM
need new clutch....
DG_Performance
Aug 5, 2003 - 10:44 AM
are you sure you are not getting a miss somewhere. I had a similar problem and it turned out to be a bad spark plug. you should check the easy stuff like that b4 you go and jump into bigger jobs like replacing the cluch! ask someone who knows a little about engines to listen to the car idle then if you have to take them for a ride so they car feel it. Best way to diagnose a problem is to get many ideas and then start with the easy ones first and work through all ideas 'till the prob is gone.
