http://toyotanation.com/forum/t36210.html
Which states that the 3rd Gen has a "shimless bucket"
Looking at the pictures here
http://www.rossmachineracing.com/3sbucket.html
Shows the difference between the 2nd gen 3SGTE bucket and the MRS bucket
My Buckets look like the MRS bucket but with a removable shim (on the underside) that I could change to alter the thickness without buying whole new buckets.... now the only trick is to source a "shim" from somewhere shouldn't be toooo hard.
Preguntas? Problemas? Comments?
I will append my own posting.....
also from the same toyota nation posting
Q: Whats shimless or shim under bucket lifters?
A: The stock bucket weighs 1.6 oz. & the MRS(MR Spyder) weighs 1.03 oz. That is a weight savings of 35.5%. When high lift cams are used with stock lifters it has caused the shims that are used for adjusting cam/lifter clearance to fly out. This eliminates that by eliminating the shim all together. That lightens the valvetrain weight and allows higher RPM limits.
Part Number Lift
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
someone might want to sticky this info? or put it into a wiki? cough chris cough
