Ok so i was thinking, take my 7afe bottom end........... lighten crank 2zz rods 4age head and pistons lighten flywheel port head 320° duration, with .400"/10.1mm lift camshafts and some weber carbs
is that crazy enough
Jun 20, 2007 - 7:08 PM
and then what? in a ~2800lb car, it'll still be slow. now, put that into a ~1800lb stripped civic, and your talking some fun.
Jun 20, 2007 - 7:11 PM
why carbs? EFI is soo much better!
pure_dx
Jun 21, 2007 - 11:11 PM
QUOTE(presure2 @ Jun 20, 2007 - 7:08 PM) [snapback]570647[/snapback]
rwd > fwd, stripped ae86 plz.
slow94st
Jun 22, 2007 - 1:03 AM
ya i gess it can go in a ae86, btw carbs rule
Hanyo
Jun 22, 2007 - 2:48 AM
so basically you made a carburated 2jzge (7th gen celica gts) without variable valve timing and lift?
ok....
MaskedMan
Jun 22, 2007 - 5:59 AM
QUOTE(Hanyo @ Jun 22, 2007 - 12:48 AM) [snapback]571208[/snapback]
ok....
2jz in a Celica? haha, i think you meant 2zzge, not 2jzge, this ain't no supra motor were working with here.
6gcSTVT
Jun 22, 2007 - 11:31 AM
you guys have some crazy ideas......
But while your at it, why not take the 7afe and throw a vtec sticker on the valve cover
I've been told each sticker adds 5hp
celica95st
Jun 22, 2007 - 8:09 PM
I have my lower ended bored out to fit the pistons of the 2000 Celica GTS motor and runs a 12:1 compression....it makes so much of a difference. only modification i had to do to fit the head back on was to mill down the top of the pistons
Kwanza26
Jun 23, 2007 - 2:50 PM
You can probably just swap in a 2ZZ and call it good. The amount of money needed to properly work the 2ZZ rods to fit the 7A will probably be pretty expensive. And those cams aren't gonna be very streetable... and you'll need a complete racing valvetrain to simply run those cams.
shubert_ae102
Jun 24, 2007 - 12:59 AM
QUOTE(6gcSTVT @ Jun 22, 2007 - 4:31 PM) [snapback]571267[/snapback]
hahahahaha
and every square inch of carbon fiber adds 2 hp.
