how would locking the differential so both wheels receive the same amount of power make it worse? the open differential is applying the most power to the wheel with the least grip and the wheel with the most grip is getting less, causing the car to steer to one side or the other when the boost hits.
http://en.wikipedia.org/wiki/Torque_steersorry, i should have specified a helical lsd, which most if not all fwd lsd's are anyways. you want to put the power down equally so that if a wheel is going to spin it'll be both wheels and not just the one.
