Full Version: Redline Magazine Nov issue
Valo666
I usually pickup a copy of Redline magazine and Fast Car every month because i like how europeans tune their cars. Any ways, i went to the local book store where i get the issues, but Fast Car wasnt in yet, so i picked up Redline. Check out the cover....
This guys got apparently the fastest street legal GT4 in the UK. Its completely gutted and kinda custom too. I would scan the article, but my scanners broken, so i took some pics instead.
he put in a set of Imprezza altezza style tails in instead of maybe going with a set of afterburners or JDM tails.
hes got a front exit exhaust too, but i donno what the point of the big section of the fender missing is.
he also made the spoiler wider too.
my fav mod of the car though, the carbon fiber mirrors. They actually look good too.
If i can get my scanner working, ill try and get the entire article put up.
snapshotgt
Shink
Awesome.
I love how he's resisted the urge to make cosmetic changes to the body kit. Two extra blisters on the hood and those side scoops, and that's about it. Sweet.
joehernandez
the tails loook excellente amigos!!! damn!!! i want mines to be like that!!!
LewFX
24 years old... ah to be young and full of money
xs94st
november?? damn i musta totally skipped this one cuz i read every car mag they have on borders' shelves :\ im a sad panda
maybe tufy should duel this guy..is he on 6gc?
BLINKYxMUNKEY
Impreza euro taillights? Eww. Other than that and the lime green, I like.
Valo666
QUOTE(xs94st @ Nov 27, 2007 - 3:14 PM) [snapback]617383[/snapback]
i doubt it..he might b on celica-club.co.uk though.
Personaly i think when tufy gets his squential tranny in, its gonna b better then this guys. He has a custom made 5spd tranny in it with stronger gears, but they arent straightcut. Plus i think tufys is a bit nicer mainly because he actually has an interior with his.
QUOTE(LewFX @ Nov 27, 2007 - 3:13 PM) [snapback]617382[/snapback]
yea..he spent $30K british pounds on the car...so pretty much...about $65K canadian on it. But thats with like 3 motors and 2 trannies too.
BloodyStupidDavey
QUOTE(Valo666 @ Nov 27, 2007 - 8:50 PM) [snapback]617393[/snapback]
or 30 British to the rest of us wink.gif 30 GBP if you wish.
Could def. do w/o those tails.
cHinaman727
I thought Tufy had the toughest GT-4? Or is Tufy not from UK? I forget...
purplegt4
wow 205 on the cover. nice too.
anybody wanna send me a copy? or can i get one here in VA
95st-celica
that side exhaust is f-ckin sick lookin....wonder what it does in the quarter??
azian_advanced
would be nice if someone could scan this, i'd really like to read about it. besides the impreza tails, rear bumper, and green engine hoses, that car is really nicely done up!
i wonder what type of suspension he's using..
LewFX
im guessing tein since he has a tein decal!
goferris
i want a copy!!! lol
he should def be a member on here if he isn't already.
x_itchy_b_x
i want his exhaust lol. bad ass.
jcaron9gt4
why is it that on the front cover, he has no right high beam, yet all the other pictures, only the left is missing?
808celica
Hmmm i wonder what Tufy has to say???? LOLz
Valo666
QUOTE(cHinaman727 @ Nov 27, 2007 - 4:09 PM) [snapback]617406[/snapback]
Tufy is from Cyprus not from the UK.
QUOTE(azian_advanced @ Nov 27, 2007 - 4:59 PM) [snapback]617429[/snapback]
im working on it. Ill re-write out all of his mods in a bit.
Sinyk
I really like what he's done to the car (with the exception of the bare interior, but hey, you gotta lose the weight somewhere I guess). All that custom stuff, truly one of a kind.
Valo666
ok..specs time
Spec
Toyota Celica GT-4 ST205 WRC
Engine:
Toyota 3S-GTE ST205 2.0lty 16V Turbo (thick wall block), bored out to 2.1L, TTE gp. crankshaft with crower rods and custom over sized JE forged pistons, APR bolts, HKS full metal head gasket, lightweight alloy cam pulleys, Frankenstein Motorsports/Kent cams head work - head racing flowed, ported and polished, with three angle valve seats, racing valves, double springs, HKS Vernier pulleys, Kent 294 cams APR cylinder head studs, HKS irdium spark plugs, Frankenstien motorsports coil pack, intake manifold, 80mm throttle body, fuel system, Holley lift pump, alloy swirling pot feeding 2x Bosch 004 fuel pumps, modified twin-entry HKS fuel trail, 4x 1000cc injectors, Garrett GT35R turbo with 0.70 compressor and 4in anti-surge inlet mounted on custom Full Race manifold with 40mm HKS external wastegate and screamer pipe. 90mm exhaust downpipe from turbo to cut down HKS superdagger silencer, washer bottel and battery relocated to boot, TRD heavt duty engine mounts, custom breather system with SFS pipework, Bailey alloy catch can, Frankenstien motorsports 4in intercooler with 3in outlet pipes, 3in stainless steel pipe to throttel body, HKS blow-off valve, pro alloy custom radiator with twin-fans, SFS hoses, TRD thermostat, Blitz 4in air filter mounted in custom alloy cold air box with custom air feed via headlight. Mocal oil cooler with custom scoop under car, recuded wiring loom (to save weight) DTA Pro management, HKS EVC 5 boost controller, outputting 588BHP @ 6932rpm 470.3 lb/ft
Transmission:
Custom Five-speed gearbox with semi-cut quaifie kit with modified bearings and syncromesh, Exedy multiplate carbon clutch with lightened flywheel, TOM'S short shift kit, TRD gearbox mounts, Cusco LSD
Brakes:
TRD discs front and rear with track compound front pads, black diamond FT rears, braided lines
Suspension:
TIEN coilovers, Whiteline and superflex bushes, cusco strut braces
Wheels and Tires:
16x8 Compomotive MO wheels with 245/45R16 BF Goodrich Tires
Exteior:
Original front bumper modified with larger vents, blended erebuni 404 spillters and side vents, headlight removed for air intake, supra indicators, stainless steel heatsheilf for exhaust, TRD sideskirts, TRD rear spoiler, Varis carbon bonnet with aero catches, Varis Carbon Fiber mirrors on custom base plates, custom vents in front fenders, rear wings widened, boot lip extended and reshaped, numberplate recess modified, rear bumper modified to fit clear imprezza rear lights, painted Gemini Silver/green
Interior:
Fully stripped out including dash, nine autometer guages mounted on front roll bar. Speedo and tach mounted on steering column, Cusco rollcage, carbon enter pannel housing starter HKS EVC boost controller, fuel pump switches, 2 sparco turino 2 seats with 3" pro race harnesses, sparco steeringwheel with launch controll buttons, chequerplate floor
94celigts
No audio.. lol? haha
Vissi
nice celi, but weres the projectors at? I thought all gt4's came with em
Valo666
QUOTE(Vissi @ Nov 28, 2007 - 4:10 PM) [snapback]617830[/snapback]
only late model ones..like 97+
dtlwrc
Crazy!!!It a beast!!
tufy
QUOTE(808celica @ Nov 27, 2007 - 11:24 PM) [snapback]617464[/snapback]
i have to say that this is a very nice moded gt four. i liked it... mostly fuel pumps and custom intake manifold.
but i am a bit confused ...
it says car is road legal.. wtf road legal with an exhoust coming out from front fender!!!
it writes '' with 588 bhp. matt has hit low 12's at santapod'' exact number!!!! then where is dyno page and low 12's hımmm... there is many cars here at 6gc.net faster than that..
about my car. its all about what you want and like.
i like a weekend race car more than a drag car, i like to go for a ride with my wife. i like to listen music when driving. i like how 18'' rims looks. smile.gif
its early to compare performance. still dont have results.
808celica
QUOTE(tufy @ Nov 28, 2007 - 9:13 PM) [snapback]618042[/snapback]
it writes '' with 588 bhp. matt has hit low 12's at santapod'' exact number!!!! then where is dyno page and low 12's hımmm... no comment
wow the famous Tufy replying to my post.
my life is almost completed.........to make it complete i would want a GT4........ laugh.gif laugh.gif laugh.gif laugh.gif ....................lol
cool cool.......................i didnt know that was the exhaust i thought it was some funnel that the turbo breathes from......................again another stupid thought.... biggrin.gif biggrin.gif
stetsonaw
wow... just, wow.
tufy
QUOTE(808celica @ Nov 29, 2007 - 7:57 AM) [snapback]618053[/snapback]
i am not different then any member here at 6gc.net, i just dont have much free time to post. smile.gif
OOBE
Looks like a Galant butt-raped an Eclipse and the rear was their child. Even the GT-FOUR spoiler looks like it came of the Galant. I hate the wheels, and the color. I only like the front. I love the performance, though. smile.gif
MaskedMan
QUOTE(jcaron9gt4 @ Nov 27, 2007 - 3:17 PM) [snapback]617461[/snapback]
Maybe it grew back? haha.
So like under his mods list for exterior, it says that he has a rear TRD spoiler, BUT it does not!
DaCCelica94
ive never seen altezza tails for a celica... where do you get them
nice race car.
i agree with tufy, if your exhaust is coming out your FRONT BUMPER, i wouldnt call that "road legal" lol
nice build...nothing out of the ordinary for me tho, mr2oc guys have been building motors like this for a few years now, as well as the guys on the other side of the pond, ect.
and i thought the horniak's exhaust was crazy with the side exit...i think this one tops it..LMAO
lubu
QUOTE(presure2 @ Nov 30, 2007 - 7:05 AM) [snapback]618213[/snapback]
nice race car.
i think they call it lake side exhaust or something....
no interrior?? no sound system.??..ashhh!!
OOBE
QUOTE(DaCCelica94 @ Nov 29, 2007 - 3:50 PM) [snapback]618207[/snapback]
celicaricerboys.com
OOBE
QUOTE(presure2 @ Nov 29, 2007 - 4:05 PM) [snapback]618213[/snapback]
nice race car.
I feel sorry for him because he spent all that money to only get that amount of horsepower. People here in the island buy Evos left and right and with a simple turbo kit pieced with AMS goodies and other parts, and a Hydra EMS, they surpass the 600 AWHP mark. He has all this race stuff, and only puts out 5XX AWHP? I think he wasted his money. I'm sure somebody shares this same feeling.
BLACKcelicaGT
QUOTE(OOBE @ Nov 29, 2007 - 9:30 PM) [snapback]618318[/snapback]
nice race car.
I don't post here much so i might be out of line but does than not contradict what the quote in your signature says?
celicaST
OOBE
QUOTE(BLACKcelicaGT @ Nov 29, 2007 - 8:47 PM) [snapback]618324[/snapback]
nice race car.
No, because the reason I posted that in my sig is because, as everybody and their mother knows, the 7A-FE is an ECONOMY-oriented engine. By pretty much anybody's (with a working brain) standard, dumping money on this engine is a waste. Many people that started with a 7A-FTE, gave up on it, quit the project, and later swapped in a 3S-GTE.
With the money most spend on a 7A-FTE project and getting it running right without breaking, a 3S-GTE swap with all the toys could be completed, and have twice the horsepower (without a sweat) that the 7A-FTE could ever push out without failure. He has a 3S-GTE, which is a PERFORMANCE-oriented engine that can handle ridiculous power. I hope this clarifies your doubt, which I'm sure was honest and not on grounds of instigating. wink.gif
tufy
QUOTE(OOBE @ Nov 30, 2007 - 2:30 AM) [snapback]618318[/snapback]
588 bhp makes less then 500 awhp...
OOBE
Oh, I didn't know it was BHP. I missed that detail. Well, more power to my statement then. tongue.gif
Insanity-74
QUOTE(presure2 @ Nov 29, 2007 - 10:05 PM) [snapback]618213[/snapback]
nice race car.
Remember its a UK car and we can do pretty much whatever we want to our cars, there are very few restrictions.
frosty
As much as people on here say they would preffer other guages than autometer ones, it's kinda sad to see all this money spent on this car and then to settle for cheaper guages....ehh, oh well....
I like the fact that it's a celica on the cover and overall I like the car, but just not massively impressed. Like some have already said, "seen better", but still enjoying it. wink.gif
OOBE
It's funny that the amateur that built the ark and all its passengers survived the flood, and the professionals that built the Titanic sank, along with everybody in it, LOL. laugh.gif
Insanity-74
QUOTE(OOBE @ Dec 1, 2007 - 12:08 AM) [snapback]618630[/snapback]
I liked it too, hence why its on my sig, like it says, never be afraid to try anything new, despite what others may think of your efforts.
Eamoncooke
Hi guys
Does anyone who who owns this car now? Nearly bought it from Frankenstein motorsport myself when Matt wanted 12000 for it but my Max was 11000, then one day I see it down to 8000 odd I nearly gave birth but when I rang it was sold with a smaller turbo etc..
Some fella bought it and has videos of it on YouTube but isn't replying and I'd like to buy it now!
