well i'm gonna drop a 4age in a friends ST and we're using the ST tranny.
i was wondering what clutch combo i'm supposed to use???
is it the 4age clutch and ST pressure plate????????? or vice versa???
Dec 4, 2007 - 4:39 PM
Pressure plate & flywheel from the 7afe, 4age clutch disc *is not correct.
*Edited.
Dec 4, 2007 - 4:42 PM
please try and post in the appropriate forum.
Kwanza26
Dec 4, 2007 - 4:48 PM
QUOTE(Supersprynt @ Dec 4, 2007 - 9:39 PM) [snapback]619631[/snapback]
Pressure plate & flywheel from the 7afe, 4age clutch disc.
Doesn't work the same for a 7AFE/4AG as it does for a 3SG/5SFE...
You use the 4AGE flywheel and clutchkit. The 4AG clutch is basically the same as the 7AFE...
Dec 4, 2007 - 5:09 PM
I tried to be logical
Will that setup plain old not work, or is it just easier to use the complete 7a kit?
Kwanza26
Dec 4, 2007 - 5:36 PM
QUOTE(Supersprynt @ Dec 4, 2007 - 10:09 PM) [snapback]619648[/snapback]
It won't work because the 7A is a 6 bolt crank while the 4AG is an 8 bolt crank. The actual flywheel itself is basically the same thing (besides the bolts), as is the clutch kit.
Dec 4, 2007 - 5:39 PM
I should have known better than to meddle in the A-series motor affairs.
Thanks for the info.
808celica
Dec 4, 2007 - 6:15 PM
so 4age everything..........
