6g25th
Mar 2, 2008 - 1:20 PM
So, i've posted a couple times about this whole pressure plate thing and one preson said that IIRC is the same thing, but unfortunately I don't know what IIRC stands for. I assume that he means that a 90-93 act pressure plate would work on a 95' 3s. Does anyone know if this is true?
scothaniel
Mar 3, 2008 - 5:49 PM
IIRC = If I Remember Correctly.
And yes, the 90-93 ACT pressure plate for the 3SGTE will work with the 95 3SGTE. I'm running one on my 3rd gen motor.
phattyduck
Mar 4, 2008 - 5:37 PM
I also have a '95 JDM 3s-gte with a 90-93 Fidanza flywheel with Spec pressure plate and Clutchnet 6-puck clutch. I think the only difference between the 2nd and 3rd gen flywheels is a slight change in the flywheel ring gear tooth pattern (I believe the later 3s-gte had more teeth on the flywheel and a slightly redesigned nose on the starter). My 3rd gen starter works just fine, but makes a little squeak noise when I start the car.
-Charlie
