highspeedjbt
Jun 17, 2008 - 4:33 PM
So I had a thread on here about the axle seal leaking from the tranny, I ended up just fixing that with a rigged up seal(made up of 2 seals and alot of sealent) so now it is on to the next problem. I have no tach or speedo signal to the dash. In fact the only thing that works on the cluster is the fuel. I have an external temp and oil gauge so that is no biggy, but I would like to know why my speedo doesnt work. The car has an st185 tranny with mr2 gears, but I am pretty sure that the sensor is fine....it is new. I was wondering what kinda mods do I need to do to get it to work in my car. Thanks and if this isn't enough info just lmk.
DEATH
Jun 17, 2008 - 4:56 PM
Join the club [tho mine is probably for a different reason]. Just to help the problem solving guru's on here - is this in a 6th gen or an ST-185?
highspeedjbt
Jun 18, 2008 - 6:51 AM
QUOTE (DEATH @ Jun 17, 2008 - 4:56 PM)
its in a 6gen. The tranny is an st185 and the engine is jdm mr2
DEATH
Jun 18, 2008 - 8:57 AM
Any particular reason why you didn't keep the stock s54 tranny [or were you ST to begin with?]
lubu
Jun 18, 2008 - 1:09 PM
QUOTE (DEATH @ Jun 18, 2008 - 9:57 PM)
He probably converted the AWD tranny to FWD. Nice..I heard something like the tach and speedo sensors on the AWD tran are mechanical not electrical.
DEATH
Jun 18, 2008 - 2:11 PM
The MR2's are cable driven and I think the 5th gens too but IDK. Alltracman would know.
As for using the AWD tranny - there are obvious reasons for wanting to do this [LSD, beefier syncro setup etc] but I've heard mixed results. The only guy I've ever talked to that did this said he was unhappy with the setup [can't remember why tho] and was at the time looking for an e153 or if not that then at least an s54.
Good luck to you highspeedjbt
