JDcelica
Jun 29, 2008 - 10:14 AM
is it posible to use the coolant line from the throttle body to feed the turbo?
Jun 29, 2008 - 10:23 AM
yes.
bccentaur3
Jun 29, 2008 - 11:14 AM
Yes thats where almost everyone taps into.
JDcelica
Jun 29, 2008 - 3:30 PM
thanks for the info. trying to finish the whole thing. only have two things left. i will post pics
bccentaur3
Jun 29, 2008 - 3:32 PM
Yeah, I'd love to see how you did it. WHen are you going to get it tuned?
JDcelica
Jun 29, 2008 - 10:27 PM
not sure yet im pissing oil every were when i start it.
CelicaST_CALI
Jun 29, 2008 - 10:30 PM
have u check ur oil lines??where is it coming from?
bccentaur3
Jun 29, 2008 - 10:33 PM
did you clamp on the oil drain hose to the oil pan union? Did you make sure your dip stick is on all the way. I was an idiot and when I installed everything I didn't notice the oil dipstick was out of the tube a little and oil was squirting all over the place.
JDcelica
Jun 30, 2008 - 7:29 PM
its coming out of the back of the engine. i rtv ed the pan twice and is still leaking now it comes out in a steady stream with the car not runing
bccentaur3
Jun 30, 2008 - 8:24 PM
Did you let the car sit and let the rtv dry? btw rtv won't work as well as the toyota gasket stuff. I had the same leaking problem so I went out and got an oil pan gasket from napa and added gasket maker with that.
JDcelica
Jun 30, 2008 - 8:27 PM
did yours drool out not started
bccentaur3
Jun 30, 2008 - 8:40 PM
Heck no...
Jul 4, 2008 - 9:50 AM
forget the RTV, that stuff is crap compared to the OEM toyota FIPG (Form In Place Gasket)
hit your local dealer, buy a tube.
make sure the mating surfaces are CLEAN!!!!!
follow the BGB instructions for reinstallation of the oil pan, and you should have no issues.
JDcelica
Jul 4, 2008 - 11:47 AM
thanks got a cork gasket and put it on and im pretty sure it stopped the leak. but i cant figer out a new one i have sprung.
